The H440 has a removable PSU bracket on thumb screws, and the PSU length is only 160mm (so not too long)
Step 1: Remove the four thumb screws holding the PSU bracket to the case
Step 2: Use provided screws in your case accessories to install the PSU to the PSU bracket. There should be four mounting points, some are off set  from eachother but should line up with screw threads on the back of the PSU.
Step 3: Install the PSU into the case, sliding the PSU through the opening and securing it to the case with the thumbscrews on the PSU bracket (reverse of step 1)
https://linustechtips.com/topic/943915-compatibility-issue/#findComment-11499817
