I'm planning to build a gaming pc (not high end, just mid range).
CPU: Intel Xeon x3440 oc'd 3.8Ghz 1.25v
GPU: Asus GTX 980 Strix (not planning oc-ing)
4x 4Gig DDR3 (1333Mhz)
1 SSD
1 Sata2 Hard drive
1 DVD drive
2x 200mm fan
1x 140mm fan
(in the future maybe + 2 or 3 140mm fan)
I have dropped all this in Cooler Master PSU calc and it recommends 586 Watt PSU.
My guess thats gonna be a 600W PSU
At my local shop the following are avaiable:
Cooler Master 600W Elite V3
Corsair SF Series™ SF600 600W SFX moduláris
Corsair CMPSU-600CXEU 600W
Be Quiet! Power Zone 600W moduláris
Be quiet! Straight Power 10 600W moduláris tápegység
Be Quiet! Pure Power 10 600W moduláris
Be Quiet! System Power 9
Cougar CMD 600 600W
Evga 600B 600W
Thermaltake TR2 TR2-600AH2NCB 600W
Thermaltake SMART DPS G 600W
Thermaltake TR2 S 600W
NJOY Legion 600W
I'm new to pc building, can you guys recommend something from the list? Do I even need 600W PSU?
https://linustechtips.com/topic/943687-help-in-psu-choosing/
1 SSD
1 Sata2 Hard drive
1 DVD drive
2x 200mm fan
1x 140mm fan
Cougar CMD 600 600W
Evga 600B 600W
NJOY Legion 600W
For one, most of these PSUs are quite crap.
Two, that system will use around 350W under OC'd load. Cooler Master's calculator is a load of garbage. Don't bother using it.
Third, the Be Quiet Pure Power 10 is the best of those. If the 500W version is cheaper then get that instead.
Edit: Father Guru pointed out that, somehow, among the mostly bad PSUs on this list, you put a Corsair SF600 on there. That's by far the best unit on there... not sure how it's in the same price bracket as the rest though.
Edited by STRMfrmXMN
https://linustechtips.com/topic/943687-help-in-psu-choosing/#findComment-11497460
Or if the OP has a bit of cash to spend and wishes to buy online they could get a Bitfenix Whisper M 450W
There are 10 types of people in this world. Those that understand binary and those that don't.
Current Rig (Dominator II): 8GB Corsair Vengeance LPX DDR4 3133 C15, AMD Ryzen 3 1200 at 4GHz, Coolermaster MasterLiquid Lite 120, ASRock B450M Pro4, AMD R9 280X, 120GB TCSunBow SSD, 3TB Seagate ST3000DM001-9YN166 HSD, Corsair CX750M Grey Label, Windows 10 Pro, 2x CoolerMaster MasterFan Pro 120, Thermaltake Versa H18 Tempered Glass.
Previous Rig (Black Magic): 8GB DDR3 1600, AMD FX6300 OC'd to 4.5GHz, Zalman CNPS5X Performa, Asus M5A78L-M PLUS /USB3, GTX 950 SC (former, it blew my PCIe lane so now on mobo graphics which is Radeon HD 3000 Series), 1TB Samsung Spinpoint F3 7200RPM HDD, 3TB Seagate ST3000DM001-9YN166 HDD (secondary), Corsair CX750M, Windows 8.1 Pro, 2x 120mm Red LED fans, Deepcool SMARTER case
My secondary rig (The Oldie): 4GB DDR2 800, Intel Core 2 Duo E8400 @ 3GHz, Stock Dell Cooler, Foxconn 0RY007, AMD Radeon HD 5450, 250GB Samsung Spinpoint 7200RPM HDD, Antec HCG 400M 400W Semi Modular PSU, Windows 8.1 Pro, 80mm Cooler Master fan, Dell Inspiron 530 Case modded for better cable management. UPDATE: SPECS UPGRADED DUE TO CASEMOD, 8GB DDR2 800, AMD Phenom X4 9650, Zalman CNPS5X Performa, Biostar GF8200C M2+, AMD Radeon HD 7450 GDDR5 edition, Samsung Spinpoint 250GB 7200RPM HDD, Antec HCG 400M 400W Semi Modular PSU, Windows 8.1 Pro, 80mm Cooler Master fan, Dell Inspiron 530 Case modded for better cable management and support for non Dell boards.
Retired/Dead Rigs: The OG (retired) (First ever PC I used at 3 years old back in 2005) Current Specs: 2GB DDR2, Pentium M 770 @ 2.13GHz, 60GB IDE laptop HDD, ZorinOS 12 Ultimate x86. Originally 512mb DDR2, Pentium M 740 @ 1.73GHzm 60GB IDE laptop HDD and single boot XP Pro. The Craptop (dead), 2gb DDR3, Celeron n2840 @ 2.1GHz, 50GB eMMC chip, Windows 10 Pro. Nightrider (dead and cannibalized for Dominator II): Ryzen 3 1200, Gigabyte A320M HD2, 8GB DDR4, XFX Ghost Core Radeon HD 7770, 1TB Samsung Spinpoint F3 (2010), 3TB Seagate Barracuda, Corsair CX750M Green, Deepcool SMARTER, Windows 10 Home.
https://linustechtips.com/topic/943687-help-in-psu-choosing/#findComment-11497478
Thanks for the advice
https://linustechtips.com/topic/943687-help-in-psu-choosing/#findComment-11497483
1 SSD
1 Sata2 Hard drive
1 DVD drive
2x 200mm fan
1x 140mm fan
Cougar CMD 600 600W
Evga 600B 600W
NJOY Legion 600W
I agree most of those are not really good, notably the Thermaltake and cougar ones. My favorite calculator is the outervision version as it is not trying to sell you anything.
Here: https://outervision.com/power-supply-calculator
I personally have had good luck with both Corsair and EVGA. Both sell cheaper power supplies for those on a budget and are known to have pretty good reliability. I can't speak for the other brands as I've never used them, but I've had a 400-watt EVGA bronze power supply for over five years now that I bought new for 30 bucks and haven't had a whisper of trouble out of it.
https://linustechtips.com/topic/943687-help-in-psu-choosing/#findComment-11497498
PSU calculators vastly overcalculate.
Corsair and EVGA both make a large sea of shitty PSUs.
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/943687-help-in-psu-choosing/#findComment-11497572
1 minute ago, KoSzOs said:
Asus Recommends 500W with this GPU, so that 570-580 what outervision and cm calulates is reasonable I think, guess with a newer cpu and mobo it should drop down to 450-500
450 would be enough with this build...
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/943687-help-in-psu-choosing/#findComment-11497581
Hey now...
There's an SF600 on that list.  ;-)
https://linustechtips.com/topic/943687-help-in-psu-choosing/#findComment-11498156
11 minutes ago, jonnyGURU said:
Hey now...
Wha....
How did that fit in the price range of a TR2...??
https://linustechtips.com/topic/943687-help-in-psu-choosing/#findComment-11498174
