Why exactly, would you get something as old as that when there's way better stuff out there?
CPU - FX 8350 @ 4.5GHZ GPU - Radeon 5700  Mobo - M5A99FX Pro R2.0 RAM - Crucial Ballistix 16GB @ 1600 PSU - Corsair CX600M CPU Cooler - Hyper 212 EVO Storage - Samsung EVO 250GB, WD Blue 1TB
https://linustechtips.com/topic/943674-cooling/#findComment-11497319
10 minutes ago, Turbo2602 said:
So I am thinking about get a AMD FX-9590
Why would you want one of those in the first place, they are complete garbage.
زندگی از چراغ
Intel Core i7 7800X 6C/12T (4.5GHz), Corsair H150i Pro RGB (360mm), Asus Prime X299-A, Corsair Vengeance LPX 32GB (4X4GB & 2X8GB 3000MHz DDR4), MSI GeForce GTX 1070 Gaming X 8G (2.113GHz core & 9.104GHz memory), 1 Samsung 970 Evo Plus 1TB NVMe M.2, 1 Samsung 850 Pro 256GB SSD, 1 Samsung 850 Evo 500GB SSD, 1 WD Red 1TB mechanical drive, Corsair RM750X 80+ Gold fully modular PSU, Corsair Obsidian 750D full tower case, Corsair Glaive RGB mouse, Corsair K70 RGB MK.2 (Cherry MX Red) keyboard, Asus VN247HA (1920x1080 60Hz 16:9), Audio Technica ATH-M20x headphones & Windows 10 Home 64 bit.
The time Linus replied to me on one of my threads:
https://linustechtips.com/topic/943674-cooling/#findComment-11497332
12 minutes ago, Turbo2602 said:
So I am thinking about get a AMD FX-9590 and I've heard that it runs rather warm would a Corsair H100i V2 be enough to cool it?
WHY?!
https://linustechtips.com/topic/943674-cooling/#findComment-11497336
Cuz it is cheep and all the reviews I had read were all saying it was a decent processor
Then buy the Ryzen 2200g if you're looking for cheap. That way you won't need to spend money on a fancy cooler.
If you won't be gaming and will be doing workstation type work then sure, the FX perhaps.
https://linustechtips.com/topic/943674-cooling/#findComment-11497366
No, it's trash, it's always been trash lol, It's impossible to cool and it will destroy most motherboards if not underclocked.
What's your budget/Country? Do you need an entire new PC? No current hardware?
https://linustechtips.com/topic/943674-cooling/#findComment-11497372
Or you can get the Ryzen 1300xif you want to get a dedicated graohics card
Main And Only Build : CPU : Ryzen 5 1600x (OC to 4.2GHz), Cooler : Thermaltake Floe Riing RGB 240 TT Premium Edition, Motherboard : Asus ROG Strix B450-F Gaming, RAM : Trident Z RGB 16GB (2*8) 3000Mhz DDR4, GPU : Gigabyte Gaming GTX 1070 TI, PSU : EVGA G3 650W 80+ Gold Certified, Storage : 250GB Samsung 860 Evo + 256GB SU800 + 2TB Seagate HDD.
https://linustechtips.com/topic/943674-cooling/#findComment-11497378
5 minutes ago, Turbo2602 said:
decent processor
In been completely terrible...
زندگی از چراغ
https://linustechtips.com/topic/943674-cooling/#findComment-11497382
I'd prefer to keep it about $1,000 US, but it's flexible. I need an entire new PC pretty much
https://linustechtips.com/topic/943674-cooling/#findComment-11497388
Then why the FX 9590...
Whatever
R7 1700 + GTX 1050ti and you should be good to go
you need a monitor and stuff as well?
https://linustechtips.com/topic/943674-cooling/#findComment-11497409
Not really I've got a decent monitor, keyboard and mouse just need a new PC
Then an R7 1700 + RX 580 8GB and you should be fine
Case and PSU are on the lower end of things, but there's not much that can be done about that.
PCPartPicker part list: https://pcpartpicker.com/list/hhmqbX
Price breakdown by merchant: https://pcpartpicker.com/list/hhmqbX/by_merchant/
CPU: AMD - Ryzen 7 1700 3GHz 8-Core Processor  ($219.90 @ OutletPC)
Motherboard: MSI - X470 GAMING PLUS ATX AM4 Motherboard  ($129.99 @ Amazon)
Memory: G.Skill - Aegis 16GB (2 x 8GB) DDR4-3000 Memory  ($170.88 @ OutletPC)
Storage: Western Digital - Blue 250GB M.2-2280 Solid State Drive  ($69.99 @ Amazon)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($43.90 @ OutletPC)
Video Card: PowerColor - Radeon RX 580 8GB Red Devil Golden Sample Video Card  ($269.99 @ Newegg)
Case: Thermaltake - Versa H22 ATX Mid Tower Case  ($36.99 @ SuperBiiz)
Power Supply: Cooler Master - MasterWatt 550W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($53.99 @ SuperBiiz)
Total: $995.63
Generated by PCPartPicker 2018-07-02 15:03 EDT-0400
https://linustechtips.com/topic/943674-cooling/#findComment-11497453
technically it's just a 8350 with an increased TDP and a higher stock clock, sort of experimental, wasn't really made for daily use but somehow AMD released it back in the day
ASUS X470-PRO • R7 1700 4GHz • Corsair H110i GT P/P • 2x MSI RX 480 8G • Corsair DP 2x8 @3466 • EVGA 750 G2 • Corsair 730T • Crucial MX500 250GB • WD 4TB
https://linustechtips.com/topic/943674-cooling/#findComment-11497539
