Can a pci-e 1x device (like a wireless adapter) go into a pci-e x16 slot?
Corsair 400C- Intel i7 6700- Gigabyte Gaming 6- GTX 1080 Founders Ed. - Intel 530 120GB + 2xWD 1TB + Adata 610 256GB- 16GB 2400MHz G.Skill- Evga G2 650 PSU- Corsair H110- ASUS PB278Q- Dell u2412m- Logitech G710+ - Logitech g700 - Sennheiser PC350 SE/598se
Is it just me or is Grammar slowly becoming extinct on LTT?
https://linustechtips.com/topic/94340-pci-e-x1-devices/
I believe so
My Build Log on PCPartPicker FX-6300, ASUS M5A78L-M/USB3, MSI 7870 GHz Edition, Corsair Vengeance LP 1x8GB, 1TB WD Blue, Fractal Core 1000 USB 3.0, Corsair CX600, and my most recent addition that I've had forever and isnt new is a 80GB WD800 for Linux, Lenovo ThinkPad X131e, ASUS Transformer TF300T, Galaxy Note 3 Sister dropped it in a puddle I now have to use a Samsung Brightside, Beyerdynamic DT990 Pro 250ohm version, Blue Yeti  #TheRealKEH-JEFF | "Sometimes, if were lucky, in Australia, a family has 2 kangaroos to pick up the kids with" - marto | Your entry here | Remember kids; just because Linus has a video on it, doesn't mean that its the best choice | ts3.wferr.com the best TeamSpeak Abide by the CoC | Looking for build help? Read this before posting |
https://linustechtips.com/topic/94340-pci-e-x1-devices/#findComment-1265494
Yes
Andres "Bluejay" Alejandro Montefusco - The Forums Favorite Bird!!!
Top Clock: 7.889 Ghz Cooled by: Liquid Helium
#ChocolateRAM #OatmealFans #ScratchItHarder #WorstcardBestoverclocker #CrazySexStories #SchnitzelQuest TS3 SERVER
https://linustechtips.com/topic/94340-pci-e-x1-devices/#findComment-1265497
Yes it will only use the pin connectors needed to run :P
Intel i7 950 @ 3.07 runing @ 4.01 / Gigabyte X58A UD3R Rev 2 / Corsair 12GB DDR3 Memory / Evga GTX 580 SC / Coolermaster CM 690 II (ver.2) / WESTERN DIGITAL 1TB 3.5" BLACK 64MB SATA3 / Coolermaster Silent Pro Gold 1200W
Samsung Syncmaster S27B370 / Noctua NH-U12P (Push/Pull Config) / MS Digital media Keyboard 3000 / Logitech G5 / Sound Blaster X-FI Titanium
https://linustechtips.com/topic/94340-pci-e-x1-devices/#findComment-1265503
My stupid IT-Systems teacher says no. But hes a moron, so yes. TRUE STORY
Personal Build Project "Rained-On"
helped building up the CPU Overclocking Database and GPU Overclocking Database, check them out ;)
#KilledMyWife #MakeBombs #LinusIsNotFunny || Please, dont use non-default grey font colors. Think about the night-theme users! ;)
https://linustechtips.com/topic/94340-pci-e-x1-devices/#findComment-1265505
Well skullbringer tell him i have a Sound Card seated in my PCE x16 slot from day one and the sound card works perfect..........
https://linustechtips.com/topic/94340-pci-e-x1-devices/#findComment-1265530
Ouch
"you need the pcie 16x slot to be wired 4x to run a 4x card in it", he meant. :mellow: nvm.
https://linustechtips.com/topic/94340-pci-e-x1-devices/#findComment-1265531
Yes, but not the other way around.
Actually, if I'm not wrong you an do it the other way also. You can have a graphics card in a 1x slot, but it would only perform at 1x. I've seen miners do it
Finally my Santa hat doesn't look out of place
https://linustechtips.com/topic/94340-pci-e-x1-devices/#findComment-1267737
Yes, you are right. It'll only operate in 1x, so it will be bandwidth limited, which luckily miners can get away with since bitcoin mining doesn't require bandwidth, only calculations.
https://linustechtips.com/topic/94340-pci-e-x1-devices/#findComment-1268202
