I have two rx580 in crossfire. I have it enabled in Radeon settings. When I go to msi afterburner it recognizes I have two cards but I can’t see any information on my second card. The second card was the card that I had installed first. Later when I got the card that is now in the first slot I just moved it down. Did I need to uninstall any drivers before I did this? Because now the screen is just black and when i have the first slot in only my screen is normal.
https://linustechtips.com/topic/942474-problems-with-crossfire/
From my knowledge the 2ND GPU is turned off or put in standby. When this happens MSI afterburner has nothing to register. It can't detect any of the sensors. Once you put the GPU under load the 2ND one turns on or comes out of standby and MSI should be able to detect at least temps, core load, and core/mem speeds.
https://linustechtips.com/topic/942474-problems-with-crossfire/#findComment-11486423
Do you know why killing floor 2 is buggy and unresponsive. I explain in my previous comment
https://linustechtips.com/topic/942474-problems-with-crossfire/#findComment-11486506
I do not. Are you running the latest driver? 18.5.1 I think.
https://linustechtips.com/topic/942474-problems-with-crossfire/#findComment-11486528
-Threads merged-
Please refrain from reposting content.
https://linustechtips.com/topic/942474-problems-with-crossfire/#findComment-11486534
