17 hours ago, GoldenLag said:
An crucial mx500 250GB SSD and a 1-2 TB HDD from seagate or a wd blue
17 hours ago, LinuxUser said:
Thank you, how big of each should I get?
as above is a good choice as a baseline if you are on a limited budget, you can add more storage down the line if you run into space issues.
