It used to power things like HHDs. These days it's more or less used as a power tap point.
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
https://linustechtips.com/topic/942393-what-does-molex/#findComment-11485718
Molex is actually the name of a business. A lot of people refer to a "Molex connector" in computing as the pin and socket connection used on older peripheral 5.25" form factor computer hardware.
There's no place like ~
Problems and solutions:
FreeNAS
Dell Server 11th gen
ESXI
https://linustechtips.com/topic/942393-what-does-molex/#findComment-11485736
It's ironic, since the 1st computer peripheral in a computer which used whats ubiquitously now known as the "Molex connector" was released in 1976, that connector was the "AMP MATE-N-LOK 1-480424-0". Molex only released a compatible connector for the AMP MATE-N-LOK 1-480424-0 in 1983, called the Molex 8981.
Anyway, that connector is used for peripheral devices, such as 5.25" floppy drives, 5.25" and 3.5" PATA and other older standards for HDDs, older graphics cards and other ISA/PCI/PCIe cards that need more power.
https://linustechtips.com/topic/942393-what-does-molex/#findComment-11486178
It isn't much used anymore.
However, you can stick all sorts of adapters - such as SATA extensions - onto a molex. They're kinda versatile like that.
Ryzen 1600x @4GHz
Asus GTX 1070 8GB @1900MHz
16 GB HyperX DDR4 @3000MHz
Asus Prime X370 Pro
Samsung 860 EVO 500GB
Noctua NH-U14S
Seasonic M12II 620W
+ four different mechanical drives.
https://linustechtips.com/topic/942393-what-does-molex/#findComment-11486259
