Hi
I have been looking around for cases for my recently built computer since I've been using my old case. Now I would like to be able to use a full profile GPU (My Asus HD 7850), A WD Blue 1TB (3.5 version not the 2.5) and a ATX PSU. Heatsink is not a problem since I alredy have a low profile 65mm Heatsink which cools very well my ryzen. I would like a portabe one (Like a PS4 type of portability), since I will be traveling lately and moving my PC a lot. I would like something like this: https://www.amazon.com/SilverStone-Technology-Mini-ITX-Computer-ML08B-H/dp/B0161UXWRA/ref=sr_1_4?s=electronics&ie=UTF8&qid=1529960718&sr=1-4&keywords=small+form+factor+case.
Oh sorry so the motherboard is Micro-ATX and IF it would be possible I would like and additional third slot for my wifi card. I CAN give up the wifi so no big deal. My budget is 72 USD but I can increase it. I hope I was clear enough on the details :) .
Specs
MSi B350M PRO-VH PLUS
8GB DDR4
Ryzen 2200G
Noctua NH-L9x65 SE-AM4 heatsink (65MM)
ASUS 7850 Direct Cu-II (Exact specs for the card here: https://www.asus.com/us/Graphics-Cards/HD7850DC1GD5/ )
If I missed anything please tell me.
Thanks in advance.
https://linustechtips.com/topic/941372-need-a-case-recommendation-sff-factor/
On 6/25/2018 at 5:49 PM, Rainbow Dash said:
Well there is almost no mATX cases in that form factor, but this is the best I could find for you
https://www.bhphotovideo.com/c/product/1179598-REG/silverstone_gd09b_m_atx_htpc_chassis_with.html
Seems fair enough tho a little bit too big than my current one. I'll check the dimensions later when I can.
23 hours ago, seon123 said:
Lian Li PC-O6? Not tiny, but it looks quite slim, and should support your hardware. It has glass, though, which might not be ideal if you move your PC around a lot.
That case seems very good for the ones I've been seeing. Only bad thing is that the price, It's 279.99$ (I think) on B&H Photo-Video-Audio soo ye.
I will search more deeper tho I think I'll get more money and build a secondary PC with ITX factor and all but with the 2400G/2200G CPU.
Sorry for not answering I've been very busy lately.
