I am looking to build a new PC within the next 2 weeks.
I am not sure whether I should go AMD or Intel but I do have a $1200 budget. I already have a 2TB SSHD,  256SSD, and Full case.
I'd like to have 16-32gb RAM and a 1070ti or 1080.
For the CPU I'm thinking Ryzen 1700x, 2700x, or Intel i7-8700k.
https://linustechtips.com/topic/939796-1200-for-a-build/
On 21/06/2018 at 5:46 PM, Itchy said:
None of those.
Intel is better suited for gaming. I suggest an i5 8400 instead of the 8700K, as you can save on your motherboard choice, and games generally don't use 6 threads.
B360 board - No Gigabyte as their VRM's are shit as some people have said
2400MHz ram - Don't need fast ram with Intel
i5 8400 - Locked, but still fast AF.
EDIT:
Make a PCPartPicker.com list and we will see what we can change in it.
hi.
https://linustechtips.com/topic/939796-1200-for-a-build/#findComment-11461876
16 minutes ago, Itchy said:
R5 2600 is about the best value CPU to get
PCPartPicker part list: https://pcpartpicker.com/list/PrQGkd
Price breakdown by merchant: https://pcpartpicker.com/list/PrQGkd/by_merchant/
CPU: AMD - Ryzen 5 2600 3.4GHz 6-Core Processor  ($189.99 @ Amazon)
Motherboard: MSI - X470 GAMING PLUS ATX AM4 Motherboard  ($129.99 @ B&H)
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-3000 Memory  ($154.99 @ Newegg)
Video Card: EVGA - GeForce GTX 1070 Ti 8GB SC GAMING ACX 3.0 Black Edition Video Card  ($469.99 @ Amazon)
Power Supply: SeaSonic - FOCUS Gold 650W 80+ Gold Certified Semi-Modular ATX Power Supply  ($71.99 @ SuperBiiz)
Total: $1016.95
Generated by PCPartPicker 2018-06-21 03:50 EDT-0400
What's your monitor resolution/refresh rate?
https://linustechtips.com/topic/939796-1200-for-a-build/#findComment-11461878
CPU: Intel - Core i7-8700 3.2GHz 6-Core Processor  ($298.99 @ SuperBiiz)
Motherboard: Gigabyte - B360 HD3 ATX LGA1151 Motherboard  ($81.99 @ SuperBiiz)
Memory: GeIL - EVO SPEAR 16GB (2 x 8GB) DDR4-3000 Memory  ($155.99 @ Newegg Business)
Video Card: MSI - GeForce GTX 1080 8GB GAMING X 8G Video Card  ($539.99 @ Newegg)
Power Supply: EVGA - SuperNOVA G2 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($60.81 @ B&H)
Total: $1137.77
Generated by PCPartPicker 2018-06-21 03:58 EDT-0400
https://linustechtips.com/topic/939796-1200-for-a-build/#findComment-11461893
Just now, Itchy said:
I have 2 HP 27es monitors. States the refresh rate is 50-60HZ.
1080p?
If so I'd suggest either this 1080p 144hz VA display, or a 4k 60hz IPS display, but those are like $300
https://www.amazon.com/Acer-ED242QR-Abidpx-FREESYNC-Technology/dp/B07598HLB5/ref=sr_1_1?ie=UTF8&qid=1524889602&sr=8-1&keywords=1080p+144hz+VA+Acer
Also look into StoreMI if you go X470.
https://linustechtips.com/topic/939796-1200-for-a-build/#findComment-11461897
might as well get a new monitor since you only have 60hz monitors.
CPU: Intel - Core i5-8400 2.8GHz 6-Core Processor  ($178.99 @ Amazon)
Video Card: Gigabyte - GeForce GTX 1080 8GB WINDFORCE OC 8G Video Card  ($504.98 @ Newegg)
Monitor: HP - OMEN 25 24.5" 1920x1080 144Hz Monitor  ($189.99 @ Best Buy)
Total: $1172.75
Generated by PCPartPicker 2018-06-21 04:00 EDT-0400
https://linustechtips.com/topic/939796-1200-for-a-build/#findComment-11461898
$189 for a TN panel and no VESA mount?
https://linustechtips.com/topic/939796-1200-for-a-build/#findComment-11463261
On 6/22/2018 at 12:57 PM, samwitwicky4599 said:
btw what did you end up going with
Here is what I ended up with.
8700K - $300
EVGA GTX 1080 SC - $550
Asus Z370 P - $100
16GB GSKILL Ripsaw V - $180
Corsair CXM 650W 80+ Gold- $50
Cooler Master 120 Lite - $40
Windows 10 Pro - $7
Total - $1227 before $30 in rebates.
https://linustechtips.com/topic/939796-1200-for-a-build/#findComment-11473041
8700K - $300
Asus Z370 P - $100
Windows 10 Pro - $7
Awesome man.
happy to know gpu prices have finally normalized
https://linustechtips.com/topic/939796-1200-for-a-build/#findComment-11473854
