I'm new to this forum, and I think this is the right place to ask. Does anyone know of any USB-A (regular) to USB-C cables that **limit** the amperage coming through? I'd like to run my phone through a slow cable over night. This is inspired by his video linked below. I know this isn't a huge deal or anything, but with overnight charging, why *shouldn't* I do things slowly?
https://linustechtips.com/topic/939406-slow-charging-cables/
Nameless cheap usb cables normally gives off 5V 0.8A power
Specs: Motherboard: Asus X470-PLUS TUF gaming (Yes I know it's poor but I wasn't informed) RAM: Corsair VENGEANCE® LPX DDR4 3200Mhz CL16-18-18-36 2x8GB
            CPU: Ryzen 9 5900X          Case: Antec P8     PSU: Corsair RM850x                        Cooler: Antec K240 with two Noctura Industrial PPC 3000 PWM
            Drives: Samsung 970 EVO plus 250GB, Micron 1100 2TB, Seagate ST4000DM000/1F2168 GPU: EVGA RTX 2080 ti Black edition
https://linustechtips.com/topic/939406-slow-charging-cables/#findComment-11458269
Cables do not limit current.
https://linustechtips.com/topic/939406-slow-charging-cables/#findComment-11458281
6 minutes ago, Casey Woodruff said:
Can they be trusted to give safe, consistent power, though?
heck no
False, poorer quality cables will limit how much power a charger can provide, for example a cable from a galaxy S3 won't give as much power as a motorola G4 Plus' cable
https://linustechtips.com/topic/939406-slow-charging-cables/#findComment-11458303
5 minutes ago, williamcll said:
heck no
You might want to look up what the difference between current, voltage, and power is.
https://linustechtips.com/topic/939406-slow-charging-cables/#findComment-11458311
V x A = W, duh? pretty much every usb cable will deliver 5 Volts, but because of different build qualities most cables will have different currents, and thus different power output.
https://linustechtips.com/topic/939406-slow-charging-cables/#findComment-11458375
When a wire has high resistance it causes a greater voltage drop over the cable.
The device then receives less than 5v because all voltage drops in a series circuit add up to the source voltage.
Anyway, the point is that an undersized cable will be converting more power into heat which is a fire hazard and you should 100% not do.
https://linustechtips.com/topic/939406-slow-charging-cables/#findComment-11458407
