Switching From Air cooling to Water, Would it make less Heat?
Solved by W-L,
9 minutes ago, Foul said:-SNIP-
The only way to keep the room cooler would be to promote airflow through it to remove the heat. Watercooling makes it more efficient at keeping the components cooler but will not cool down or heat up the room more since your heat output from the components is still the same.
Featured Topics
RvG Iced ·
Rogers24 ·
Posted in Troubleshooting1 -
TurkishBTW ·
Posted in Peripherals0 -
1
kennethk ·
Posted in Peripherals1 -
5
BTSHalfLifeAndGmodFan2003 ·
Posted in Storage Devices6 -
6
