Hello everyone.
i recently found a laptop with pretty good value. It's an Acer Aspire 3 with a Ryzen 5 2500U, so I thought it was a great buy for ~$650. But there's one problem. Acer had to include a Radeon 535 GPU that's half the power of the Vega 8 in the Ryzen 5. I'd pry it out with the board if I could.
So, will disabling the GPU help battery life? And by how much? Thanks very much in advance.
Acer Aspire 3 A315-41G-R4BW
Ryzen 5 2500U
4GB RAM
Radeon 535 Graphics (TDP is 50W)
https://linustechtips.com/topic/938397-disabling-gpu-for-battery-life/
12 minutes ago, xContrastx said:
That's just the integrated GPU
But I think the aspire 3 has a shit TN display if i remember right
almost all of the current Ryzen 5 laptops seem limited in one way or another, a lot of new ones were just announced at computex though, or shown off rather. So some of them might be really good. There's also a rumored 45W TDP model coming.
Interesting. I wonder if dual graphics is still a thing.
Desktop benching:
Isn't the iGPU the Vega 8? Not the Radeon 535? Not to mention the "G" in the model number (-41G-), meaning it has a dedicated GPU. By comparison, an Aspire 3 without a GPU is called A315-41.
None of the Ryzen APU laptops come with a dedicated GPU.
6 minutes ago, xContrastx said:
So there's misinformation in this page?
http://www.villman.com/Product-Detail/Acer_A315-41G-R4BW
Pretty sure something is wrong there, why would they put a dedicated GPU inside a machine that has less cores than the APU? It might have dedicated graphics, but it seems to me I'd be slower than the built in graphics, guess it's an asia only model?
http://www.yugatech.com/news/acer-aspire-3-with-amd-ryzen-processors-now-available-at-villman/
https://www.techpowerup.com/gpudb/3209/radeon-535-mobile
Anyways, if I do get it, how much of an effect will disabling the GPU have on battery life and heat?
You probably won't have any option to outright disable it if it does have one
But it looks like it has a horrible display anyways
15.6″ HD (1366 x 768) resolution
Look for something with a 1080p IPS panel.
Try and see if a local shop or something has one, because this chart seems like it would be accurate in that the dedicated GPU is slower than the integrated GPU
Yeah, it could be inaccurate. I did check a physical shop a few days ago. It turns out that the screen was 1080p. But I'm not sure if it's TN or IPS, and if there is a dedicated card. I should check it again soon.
The normal one comes with the 1080p TN display and just an R5 2500U
https://www.amazon.com/Acer-Aspire-A315-41-R001-Ryzen-Windows/dp/B07BJTF8QC
The Swift 3 has a 1080p IPS display, though at that price you could just get an i5/i7 + GTX 1050
https://www.amazon.com/Acer-Swift-Ryzen-Windows-SF315-41-R8PP/dp/B078BC1YL2
Acer did that on Aspire 3 models
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
Why would they put in a GPU that's worse than the onboard graphics?
No idea. There are many similar Intel based models too
Desktop specs:
  • 2 weeks later...
11 minutes ago, Paranaxth said:
the laptop runs faster when charged?
this is for sure
Desktop specs:
