So I need more help. I just finished my computer and I am trying to download windows on it. I downloaded the iso file on my Mac but I can't seem to be able to move the file to my USB. It says that the file can't be copied because of the format. I just want to finish my computer
https://linustechtips.com/topic/938240-need-help/
Use the Windows 10 Media Creation tool to format and put Windows onto the USB so it can be booted and installed.
Just putting the ISO onto a USB won't let you boot from it unless you burn the ISO to the USB directly.
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
https://linustechtips.com/topic/938240-need-help/#findComment-11447679
but when I go onto the website it only shows an iso option. I can't find the media creation tool
https://linustechtips.com/topic/938240-need-help/#findComment-11447686
https://www.microsoft.com/en-us/software-download/windows10
Download tool now should be in the center.
Prior Build Log/PC:
https://linustechtips.com/topic/938240-need-help/#findComment-11447689
1 minute ago, SHG_Marsh said:
yea I can't find it. It only shows an ISO file option
Ah, right, you're on a Mac. Completely glossed over that since the installer is an exe file.
Try this:
https://www.windowscentral.com/how-create-windows-10-installer-usb-drive-mac
Prior Build Log/PC:
https://linustechtips.com/topic/938240-need-help/#findComment-11447696
Try this:
will boot camp work on my 2010 Mac? Because it is telling me to format my USB but idk how to
https://linustechtips.com/topic/938240-need-help/#findComment-11447722
So somehow the graphics card I have has windows on it. There is an account and the previous owner is sending me his password. Do you know how to clear everything? I don't want to delete system 32
https://linustechtips.com/topic/938240-need-help/#findComment-11447744
That doesn't make any sense. GPUs don't have OS. You install OS on drive, either HDD or SSD. If there's any previous account, ignore it. It's probably for GeForce Experience or AMD equivalent or something similar. Not needed for OS. You don't even need MS account to install and use Windows.
If you want to do clean install, format target drive with Windows installer.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/938240-need-help/#findComment-11449622
but the thing is is that I brought a brand new hard drive from a store and the GPU is the only thing that is used. So somehow maybe the os is tied to the GPU. Also i contacted the previous owner and he had the right password.
https://linustechtips.com/topic/938240-need-help/#findComment-11459724
Just not possible. GPUs don't have long term memory. They have firmware, but thats different than OS.
https://linustechtips.com/topic/938240-need-help/#findComment-11460126
