Hey guys, so sytem specs are the following:
- Z97 Gaming 5 motherboard
- 2X GTX MSI Nvidia 960s
-850 corsair PSU
-I7-4790K Intel CPU
- 32GB of DDR3
OS - Windows 10
The second 960 wont run while playing overwatch. I've confirmed this with MSI afterburner which can see the card but has no increase in power nor temp to it while in game.
Is there a setting I'm missing or software even for SLI? I have updated GPU drivers and motherboard bios.
https://linustechtips.com/topic/937249-gtx-960-sli-problems/
-850 corsair PSU
-I7-4790K Intel CPU
- 32GB of DDR3
OS - Windows 10
A lot of new games don't support SLI. It's basically no longer recommended by Nvidia and it's not really supported well anymore.
Judge a product on its own merits AND the company that made it.
How to setup MSI Afterburner OSD | How to make your AMD Radeon GPU more efficient with Radeon Chill | (Probably) Why LMG Merch shipping to the EU is expensive
Oneplus 6 (Early 2023 to present) | HP Envy 15" x360 R7 5700U (Mid 2021 to present) | Steam Deck (Late 2022 to present)
Mid 2023 AlTech Desktop Refresh - AMD R7 5800X (Mid 2023), XFX Radeon RX 6700XT MBA (Mid 2021), MSI X370 Gaming Pro Carbon (Early 2018), 32GB DDR4-3200 (16GB x2) (Mid 2022
Noctua NH-D15 (Early 2021), Corsair MP510 1.92TB NVMe SSD (Mid 2020), beQuiet Pure Wings 2 140mm x2 & 120mm x1 (Mid 2023),
https://linustechtips.com/topic/937249-gtx-960-sli-problems/#findComment-11439032
As @AluminiumTech said many new games simply don't support SLI, many developers are not investing in the feature and Nvidia themselves are trying to move away from supporting it. A few years ago, yeah SLI was something worth while doing and supporting but now we've got single cards that can compete with SLI set-up's consumers are no longer seeing the benefits of it and are just buying single cards instead. Honestly I think in two years time we may never see SLI again, and if it does still exist Nvidia is going to have to invest money into a program that will try and make SLI worth while doing again.
زندگی از چراغ
Intel Core i7 7800X 6C/12T (4.5GHz), Corsair H150i Pro RGB (360mm), Asus Prime X299-A, Corsair Vengeance LPX 32GB (4X4GB & 2X8GB 3000MHz DDR4), MSI GeForce GTX 1070 Gaming X 8G (2.113GHz core & 9.104GHz memory), 1 Samsung 970 Evo Plus 1TB NVMe M.2, 1 Samsung 850 Pro 256GB SSD, 1 Samsung 850 Evo 500GB SSD, 1 WD Red 1TB mechanical drive, Corsair RM750X 80+ Gold fully modular PSU, Corsair Obsidian 750D full tower case, Corsair Glaive RGB mouse, Corsair K70 RGB MK.2 (Cherry MX Red) keyboard, Asus VN247HA (1920x1080 60Hz 16:9), Audio Technica ATH-M20x headphones & Windows 10 Home 64 bit.
The time Linus replied to me on one of my threads:
https://linustechtips.com/topic/937249-gtx-960-sli-problems/#findComment-11439068
Hey guys! Thanks for the swift replies.
When I looked into this, I did realize that not all games support SLI, but even with that in mind, games like skyrim, DS3, or any other games that are supposed to be compatible with sli just won't run the card.
Any ideas come to mind  as to what's going on?
Thanks again!
https://linustechtips.com/topic/937249-gtx-960-sli-problems/#findComment-11439145
Make sure you're running in DX11 mode + enable SLi in the nvidia control panel + make sure SLi bridge is seated correctly.
Maybe they removed SLi support or nvidia dropped the profile. You might need to go digging in nvidia inspector and see what SLi compatibility bits work and which ones don't.
SLi is enthusiast tier stuff. You have to play with it to get it to work. Some games will not work at all while some will work after some tweaking. Worth it though if it does work especially at higher resolutions.
https://linustechtips.com/topic/937249-gtx-960-sli-problems/#findComment-11439172
