https://linustechtips.com/topic/936573-help-me-quick/#findComment-11432531
4 minutes ago, TTQGaming said:
Correct.. it is not my drive i borrowed it..
Can the person you borrowed it from tell you if it has any important data on it besides the W7 installer? If it doesn't then just reformat the stick.
Also assigning the VM a virtual CD-ROM and assigning the CD-ROM a windows7.iso its a simpler way of installing the OS with less risk to physical hardware.
https://linustechtips.com/topic/936573-help-me-quick/#findComment-11432545
it only had win7 installer
https://linustechtips.com/topic/936573-help-me-quick/#findComment-11432552
Then format away. If you have the windows7.iso handy you could even reinstall it for your associate. Like it never even happened ;).
https://linustechtips.com/topic/936573-help-me-quick/#findComment-11432567
I don't have it and i cannot install it anywhere(the iso)
Im trying to find the Iso
online
https://linustechtips.com/topic/936573-help-me-quick/#findComment-11432570
Was it any special version like pre-activated or was it just a run of the mill normal copy? If you can find one or tell your friend the USB drive didn't work and ask them for the .ISO so you can use the CD-ROM method then you can use Rufus to install the .ISO back onto the thumb drive. It'd only take a few minutes.
https://linustechtips.com/topic/936573-help-me-quick/#findComment-11432585
Preactivated....
It was actually my dad's and i am trying to figureout if he deleted it or not
https://linustechtips.com/topic/936573-help-me-quick/#findComment-11432588
Preactivated....
I'm sorry to say but if your dad deleted the .ISO thinking the USB installer would last forever then he's less than the smartest person.
Always, always, always have backups.
https://linustechtips.com/topic/936573-help-me-quick/#findComment-11432592
55 minutes ago, TTQGaming said:
I tried to install a windows 7 operating system to a virtual machine(virtualbox) from an usb drive(worked before)... I tried to do it.. i failed.. so i decided to take it out... and it didn't have any storage.. help
There isn't any rule that says you should put the topic in the title?
https://linustechtips.com/topic/936573-help-me-quick/#findComment-11432686
