On 6/10/2018 at 10:49 AM, H20Burner said:
What is the smallest possible case that can fit a eatx board with a triple rad? Im thinking about upgrading from my motherboard box.
Phanteks Enthoo Pro M TG is about as small as you'll get.
https://linustechtips.com/topic/936244-smallest-possible-case/#findComment-11435268
This case can only support very small EATX so compare the size of your motherboard to the size that is said on their site (262mm if I remember correctly) Corsair 400c is small, fits eatx, and a 360mm rad in front. Although from my experience cramming a lot of stuff in a small case is not that good of an idea. I cannot wait to upgrade from my 400c to the phanteks evolv X when it comes out.
https://linustechtips.com/topic/936244-smallest-possible-case/#findComment-11435960
I wish E-ATX was more standardized. It's the 200mm fans of motherboards
https://linustechtips.com/topic/936244-smallest-possible-case/#findComment-11435970
It is really a bummer. My eatx wouldn't fit in the pro m which is one of my favorite cases. So I opted for the 400c and regret it. Not very good cable management, my gpu cables push agains the side panel, and I now hate front mounted radiators
https://linustechtips.com/topic/936244-smallest-possible-case/#findComment-11435975
I solved this already. Getting a corsair air 540.
https://linustechtips.com/topic/936244-smallest-possible-case/#findComment-11436103
