https://www.amazon.com/dp/B0087X728K/?tag=pcpapi-20
Really depends how much you use, how many times you mess up and have to re-apply. You should have several applications with plenty to spare in this tube.
Personal Computer Build:
CPU: i7-4790k | Motherboard: Asus Z97-A | RAM: 16GB G. Skill | Graphics Card: Nvidia Geforce Gtx 1070 TI Founders Edition | Case: Corsair 750D | Storage: Samsung 850 Evo 250GB / Western Digital Black 1TB / Western Digital Blue 1TB | Power Supply: EVGA 750watt SuperNova Gold Rated | Displays: 3 VG248QE 24" 144hz, 1MS | CPU Cooler: Corsair H100i V2 | Keyboard: Razer Chroma BlackWidow
https://linustechtips.com/topic/934377-i-need-a-little-help/#findComment-11412140
I personally like MX-4 for laptops. The smallest amount they sell will be vastly more than enough for two laptops.
https://linustechtips.com/topic/934377-i-need-a-little-help/#findComment-11412144
I can't recommend AS5 on laptops. I've see it get on the surrounding pads, and it destroyed a CPU.
https://linustechtips.com/topic/934377-i-need-a-little-help/#findComment-11412145
i always recommend Thermal Grizzly Kryonaut.
How do Reavers clean their spears?
|Specs in profile|
The Wheel of Time turns, and Ages come and pass, leaving memories that become legend. Legend fades to myth, and even myth is long forgotten when the Age that gave it birth comes again.
https://linustechtips.com/topic/934377-i-need-a-little-help/#findComment-11412163
Mx4 or kryonaut are both really good options as they are highly conductive and easy to use while not being electrically conductive as arctic silver 5. IC diamond is also good though it will pretty much without fail scratch the die which I've had happen on every cpu and gpu I've put it on. :( great stability for long term use and non electrically conductive though.
https://linustechtips.com/topic/934377-i-need-a-little-help/#findComment-11412722
