1 minute ago, YourNewPalAlex said:
cheapest cooling solution for oveclocking an i5-8600K?
Cheap and Overclocking dont go together.
Linux Daily Driver:
CPU: R5 2400G
Motherboard: MSI B350M Mortar
RAM: 32GB Corsair Vengeance LPX DDR4
HDD: 1TB POS HDD from an old Dell
SSD: 256GB WD Black NVMe M.2
Case: Phanteks Mini XL DS
PSU: 1200W Corsair HX1200
Gaming Rig:
CPU: i7 6700K @ 4.4GHz
Motherboard: Gigabyte Z270-N Wi-Fi ITX
RAM: 16GB Corsair Vengeance LPX DDR4
GPU: Asus Turbo GTX 1070 @ 2GHz
HDD: 3TB Toshiba something or other
SSD: 512GB WD Black NVMe M.2
Case: Shared with Daily - Phanteks Mini XL DS
PSU: Shared with Daily - 1200W Corsair HX1200
Server
CPU: Ryzen7 1700
Motherboard: MSI X370 SLI Plus
RAM: 8GB Corsair Vengeance LPX DDR4
GPU: Nvidia GT 710
HDD: 1X 10TB Seagate ironwolf NAS Drive.  4X 3TB WD Red NAS Drive.
SSD: Adata 128GB
Case: NZXT Source 210 (white)
PSU: EVGA 650 G2 80Plus Gold
The stock cooler...?
You can get like a hundred MHz overclock, with throttling, and very loud noise.
Depends on how much you overclock it. Perhaps the NH-D14 is a good and somewhat affordable option?
CPU: Intel Core i7-950 Motherboard: Gigabyte GA-X58A-UD3R CPU Cooler: NZXT HAVIK 140 RAM: Corsair Dominator DDR3-1600 (1x2GB), Crucial DDR3-1600 (2x4GB), Crucial Ballistix Sport DDR3-1600 (1x4GB) GPU: ASUS GeForce GTX 770 DirectCU II 2GB SSD: Samsung 860 EVO 2.5" 1TB HDDs: WD Green 3.5" 1TB, WD Blue 3.5" 1TB PSU: Corsair AX860i & CableMod ModFlex Cables Case: Fractal Design Meshify C TG (White) Fans: 2x Dynamic X2 GP-12 Monitors: LG 24GL600F, Samsung S24D390 Keyboard: Logitech G710+ Mouse: Logitech G502 Proteus Spectrum Mouse Pad: Steelseries QcK Audio: Bose SoundSport In-Ear Headphones
60$ is your budget for cooler. I searched online and people said the cooler master master liquid 240
well you have 60$ Whats gonna give me the most overclocking potential
A decent motherboard and lvl 100 luck in the silicon lottery
i7 8700k @ 5.0Ghz | ASUS Strix Z370-F Gaming | Cryorig R1 Ultimate | 16GB Corsair Vengeance LPX DDR4-3000 | ASUS Strix GTX 1080 8GB (A8G) | WD Black 500GB PCIe NVMe | Samsung 750 EVO 120GB | Western Digital Black Series 1TB | Fractal Design Define R6 TG | Corsair RM750x
"Everyone says that I'm incredibly unlucky at the Silicon Lottery. In truth, I just persist in believing that 106°C is an acceptable temperature."
- Me, 2018
21 minutes ago, YourNewPalAlex said:
hah
when you overclock you are exponentially increasing the amount of heat your CPU is putting off.  cheeping out on cooling is THE LAST THING you should do in that situation.
I would stick to stock and save your money for a decent setup.
Linux Daily Driver:
CPU: R5 2400G
Gaming Rig:
Server
CPU: Ryzen7 1700
GPU: Nvidia GT 710
SSD: Adata 128GB
CPU: Intel Core i5-8600K [Delidded | Frequency: 5.1GHz | vCore: 1.45v - Fuck Intel | Cache: 4800MHz | VCCIO: 1.175 | SA: 1.20]
GPU: MSI GTX 1080 Ti ARMOR 11G OC [Core: 2113MHz | Memory: + 1000MHz | Voltage: 1.181v | XOC BIOS]
RAM: TEAM GROUP DARK PRO EDITION [Capacity: 16GB - 8GB x 2 | Frequency: 3866MHz | Timings: 16-16-16-36]
Motherboard: ASUS PRIME Z370-A
PSU: SeaSonic PRIME Ultra 1000W
Case: Fractal S2 Meshify
CPU Block: EK Velocity | GPU Block: EK-FC1080 GTX Ti TF6 Radiators: x2 HWLabs SR2 360MM  Pump / Res: EK-XRES 140 Revo D5 PWM Fans: x6 Noctua NF-F12
Primary Monitor: Acer Predator XB271HUbmiprz [Refresh Rate: 165Hz | Resolution: 2560 x 1440]
Secondary Monitor: ASUS VG248QE [Refresh Rate: 144Hz | Resolution: 1920 x 1080]
UPS: APC Smart-UPS RT 2000VA [Online | Double-Conversion]
Benchmarks: 3DMark TimeSpy - First [1 out of 8571]
