Building new computer soon.
Going to have a 4670, planning to push it to around 4.3 - 4.5 ghz
Also getting the h100i cooler.
I'm pretty set on getting the corsair sp120s(quiet edition), yes I do know there are fans that perform better, but I just wanna know will these suffice for my cooling needs?
Has anyone had any issues with the corsair sp fans with the h100i? I've heard replacing the fans can sometimes bring up some issues with this particular cooler.
https://linustechtips.com/topic/93294-h100i-fan-replacement/
they should be fine they are not super with pressure but they should do much better than the originals that come with the h100i
Current Build :
CASE: Fractal Design R4 w/Window CPU: Intel 4930K,  RAM: 16GB Ripjaws Z 2133Mhz  Cooling: H100i  MotherBoard: Asus P9x79 Pro , PSU: CS750M   Storage: 2x Samsung 840 Pro 256Gb , 1Tb Seagate Barracuda, 500GB WD Black,  Graphics: Gigabyte GTX 780 Windforce 3GB,  Monitors: AOC G2460PG ( G sync monitor), Edge10 24" 1080p , 24" 1680*1020p monitor ( LCD)  Microphone: Blue Yeti  Keyboard: Cougar 700k  Phone: Samsung Note 3  Headphones: Sennheiser HD598
Laptop:
 CPU:
4710MQ  Ram: 8GB 1600MHz Storage:120Gb 840 Evo + 1Tb 5400Rpm HDD  Graphics: GTX 850M 2GB   Screen: 1080p IPS
https://linustechtips.com/topic/93294-h100i-fan-replacement/#findComment-1254546
SP120s will suffice, even running on low rpm, they are really good.
Personal Build Project "Rained-On"
helped building up the CPU Overclocking Database and GPU Overclocking Database, check them out ;)
#KilledMyWife #MakeBombs #LinusIsNotFunny || Please, dont use non-default grey font colors. Think about the night-theme users! ;)
https://linustechtips.com/topic/93294-h100i-fan-replacement/#findComment-1254547
Noctua NF F12's.  I know Linus recommends them as well.  Although they're not the most eye-pleasing fans out there...
The stock fans are fine though, and you shouldn;t have any problems with those.
i think he choose the sp120's because he did not have £30 to spend on fans which is fair :3 but Nf-f12's are really good
Current Build :
Laptop:
 CPU:
https://linustechtips.com/topic/93294-h100i-fan-replacement/#findComment-1254550
I would go with SP120's as they're pretty good and way more nice to look at
Cpu: Intel i5- 4570 | Ram: Crucial DDR3 8GB | Video Card: Evega GTX 660 Ti 2GB Super Clocked
Monitor: Philips 24" | Keyboard: CM Storm Quickfire TK | Mouse: Logitech G700s |
Steam
https://linustechtips.com/topic/93294-h100i-fan-replacement/#findComment-1254590
appreciate the feedback guys. I love the performance on the noctua fans, they are a bit more than I'd like to spend on fans tho. Also I would probably only get them if I didn't have a windowed case, they would just clash with the look of the rest of my build.
https://linustechtips.com/topic/93294-h100i-fan-replacement/#findComment-1254618
Honestly, it is not really worth replacing any stock fans other than for aesthetics. The performance increase, if any, would be better spent on actual components. Only when buying heatsinks/rads and fans separately is when the whole "which fan is better" discussion is worth it.
https://linustechtips.com/topic/93294-h100i-fan-replacement/#findComment-1254743
