How Do i overclock my cpu
Solved by Kushagra_kj10,
If you have a unlocked CPU you meet the first requirement then u need a overclockable motherboard (usually the ones which have B or Z in them like B350 etc). If you meet both requrements the you r good to go.
Open the BIOS and change the clock speed which you may experiment a lot cuz it won't blow ur CPU it will just crash but increasing the volts and wattage is something you should try not to experiment with too much.
Happy overclocking
