I don't know if anyone here can help me with this problem but this is my last resort....So I have talked to plenty of people to try and get this shit sorted out but cannot figure it out. I run a bot that runs monster super league and all of a sudden it stopped working correctly. the "adb" which let's it swipe does not work anymore. best I can explain it I doubt many people know what much of this means. Someone said it was a firewall/virus problem but it can't be I disabled both still the same thing.
CPU: i9 19300k////GPU: RTX 4090////RAM: 64gb DDR5 5600mhz ////MOBO: Aorus z790 Elite////MONITORS: 3 LG 38" 3840x1600 WIDESCREEN MONITORS
https://linustechtips.com/topic/930460-android-emulator-nox-problem/
1 minute ago, IgorM said:
Try using bluestacks instead
Bluestacks is terrible because you have to install bloatware. Don't use bluestacks.
Did you update to a newer version of nox?
Want to know which mobo to get?
Choose whatever you need. Any more, you're wasting your money. Any less, and you don't get the features you need.
Only you know what you need to do with your computer, so nobody's really qualified to answer this question except for you.
chEcK iNsidE sPoilEr fOr a tREat!
2 minutes ago, IgorM said:
yeah, but it is the one that works kind of reliably
unfortunately have to kinda disagree on that front too.. bluestacks for me was more troublesome than android x86 in a VM.
the bot doesn't work with blue stacks and the bot doesn't like the new version. the person who introduced me to this bot says this is the best version.
it stopped working over night for some reason.
No, its the one with most annoying features, including ransom demands if you for some reason need to reinstall it.
Something updated. Maybe the game you are using it with to remove such cheating-styles.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
