Pump and Reservoir
Solved by Dreaper,
3 minutes ago, mikelthebeast said:The max size on their res/pump combo is 140
Im wanting a 250
http://www.performance-pcs.com/xspc-x4-photon-270-reservoir-pump-combo-v2.html
From what ive been told the top dogs are mostly Sigularity PCs being one of the best, EKWB, places like that but as long as its a D5 pump you should be good.
