Yes definitely, if your streaming is encoding in the CPU and stressing it a bit (which yours is).
Just make sure that your overclock is stable because it is not fun to lose a stream because of a crash.
PC:
AMD Ryzen 9 5900X | AMD Radeon RX 7900 GRE | 32 GB RAM | Arch Linux
Laptop:
MacBook Pro 13" (2019) | Intel Core i5 8279U | 8 GB RAM | macOS
Server:
Intel Core i7 6700K | 16 GB RAM | 2 TB HDD | Debian Linux
I use my gpu as fortnite is cpu intensive and my gpu doesnt use much
12 minutes ago, DrThots said:
Does it improve my FPS and cpu usage efficiency. It use to be 95% when playing fortnite, now its lower than 90 most of the time. Is that something to oc my i5 6600k from 3.5 to 4.2
based off gaming bench marks from techtubers theres a minimal FPS gain to overclocking your CPU in fortnite for what ever reason it just doesnt care all that much about clock speed
if its the CPU holding you back then yah. generally your CPU does all the encoding stuff so more CPU power will help
Builds:
