i have a dark rock pro 3 and i was thinking about buying a phanteks p400s and im wondering if my cooler will fit
if it doesn't, suggestions that do and have good reviews are welcome(i want to pay around 100 euros)
gaming system: Intel core I9 12900ks / biostar Z690A valkyrie / 4x8gb corsair Vengeance @3333Mhz ram / RX 7900XTX pulse gpu / Thermalright peerless assassin 140 /Coolermaster Qube 500 case / Be Quiet Dark Power Pro 12 1500w power supply
laptop: Dell xps 9510, 3.5k OLED, i7 11800h, rtx 3050 ti, 2x16gb DDR4 @ 3200Mhz, 1TB main drive, 2TB add in ssd
https://linustechtips.com/topic/929678-does-my-cooler-fit/
Based on what I see in this build, the Dark Rock 3 fits really well, making me think that the Pro may have a little room.
https://pcpartpicker.com/b/tX4CmG
This guy is also using the Pro 3 with a Define R4, which I THINK is about the same size as the P400S.
https://pcpartpicker.com/b/xWgLrH
You may have to remove the exhaust fan completely to fit it, but that's just a sacrifice you're going to have to take.
And besides, why do you have to have a Dark Rock Pro 3?  There are plenty of other great coolers on the market.  You could also  get a new case.  Your choice though.
https://linustechtips.com/topic/929678-does-my-cooler-fit/#findComment-11367565
He already has it. Hes thinking about buying a case...
QUOTE/TAG ME WHEN RESPONDING
Please Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It. Take Time & Explain
New TOS RUINED the meme that used to be below :(
https://linustechtips.com/topic/929678-does-my-cooler-fit/#findComment-11367588
Dark Rock 3 is 160mm. I wasn't going by fans, I was going by actual heatsink heights. Like you said, it could fit but it will definitely be hitting the side panel if it does.
The R4 supports CPU coolers up to 170mm
I'd get a different case, if it were my build. I have had a few Phanteks P400, they are okay, I just moved to more Fractal Design cases. Better air, imo.
https://linustechtips.com/topic/929678-does-my-cooler-fit/#findComment-11367592
What about the meshify c?
https://linustechtips.com/topic/929678-does-my-cooler-fit/#findComment-11367636
59 minutes ago, iwalkwithedead said:
Yes, it will fit in the Meshify C. Meshify has 172mm limit. All good! :)
Example
Alriiiight thanks for the help?
https://linustechtips.com/topic/929678-does-my-cooler-fit/#findComment-11367821
  • 2 weeks later...
  • 3 months later...
On 6/3/2018 at 4:36 AM, Frapogalo said:
I have the Phanteks p400s TG and i fitted the Dark Rock Pro 4 , so i think dark rock pro 3 will fit too
How well does it fit, Frapogalo? I'm thinking about the same setup as you.
Does it touch the glass or anything?
https://linustechtips.com/topic/929678-does-my-cooler-fit/#findComment-11792489
