Will Beam.NG Drive run well on my gear?
SirGeneral
from one to ten, how well will Beam.NG Drive run on this gear?
aforementioned gear:
CPU: Athlon X4 845
GPU: Nvidia GTX 1050
RAM: 8GB DDR3
heck.
You can run at 30fps steady
just buy and refund if it's not ok
My life
hmm, will try
also I forgot how to refund games so instructions would be nice
heck.
CPU: Athlon X4 845
RAM: 8GB DDR3
my cousin has the same graphics card as you and he said 30 fps did not feel smooth at all on that game because thats all he got and he said it was not playable at all so he refunded it so dont get your hopes up and he had a i7 7th gen
CPU: Athlon X4 845
RAM: 8GB DDR3
I have been playing beam.ng for a while and it is at times cpu heavy, so be extra careful with amount of physics objects you are using.
System
  • CPU
    i7-7700k at 4.6ghz
  • Motherboard
    Asus ROG Z270-E
  • RAM
    Gskill 16gb 2400 RGB
  • GPU
    MSI GTX 1080 Duke
  • Case
    Corsair 750D
  • Storage
    Samsung 850 evo 500gb
     WD black 4tb
     WD blue 1tb
     Kingston ssdnow v300 128gb
  • PSU
    Corsair HX750
  • Display(s)
    2x Asus - VG248QE 24" 144Hz 1080p
  • Cooling
    Corsair H110i
  • Operating System
    Windows 10 Pro
i doubt he can run the game my cousin had way better specs then him but with the same gpu and he would struggle to get 30 fps and he said it was completely unplayable
i can run it on my laptop with a 1050 and 7700hq so its probably what is happening at the time rather then the game as a whole.
System
  • CPU
    i7-7700k at 4.6ghz
  • Motherboard
    Asus ROG Z270-E
  • RAM
  • GPU
    MSI GTX 1080 Duke
  • Case
    Corsair 750D
  • Storage
     WD black 4tb
     WD blue 1tb
  • PSU
    Corsair HX750
  • Display(s)
  • Cooling
    Corsair H110i
  • Operating System
    Windows 10 Pro
