Kind of lost control of my mouse, Help!
Ridska
My cursor is wondering on its own without me even touching it, i can move my mouse with some control but when i let go, it just wonders off.
My mouse is the FUNC MS-3 r2
Thanks for the help in advance.
(⌐■_■)
5 minutes ago, Septimus said:
Is it just drifting off in one direction, or does it move to certain points on the screen?
its drifting everywhere, there is no certain point.
example, if i move it right , it will start drifting left if i move the mouse multipul times right then it will drift right.
(⌐■_■)
What surface is the mouse on? If it's reflective it can mess with the sensor.
I edit my posts a lot.
example, if i move it right , it will start drifting left if i move the mouse multiple times right then it will drift right.
Is it an optical or laser sensor in the mouse? It sounds like the sensor could just be bad.
If you unplug your mouse does it stop? If so probably a bad mouse.
i tried that, no dice.
mouse problem.mp4
(⌐■_■)
Do you have any other input devices plugged in such as a gamepad?
nope.
(⌐■_■)
i really do not want to spend any money on a new mouse, it was working perfectly yesterday.
(⌐■_■)
mouse problem.mp4
This suggests it's a software problem. Have you installed any new software or drivers recently?
sense func is out of buisness, i do not know where to get the newest mouse drivers, if you can help me with that, that would be awesome.
(⌐■_■)
