a few weeks a go i bought a new splitter and since then i have been noticing worse ping and lag spikes
is the problem related to it?
i use my splitter as an extension to the main wire
so will using connecting the router directly to the main wire and using wifi adapter on the pc solve this problem?
https://linustechtips.com/topic/927963-splitter-problem/
If you had problems only since then, it's the splitter.
CPU i7-7700k 5.5GHz Delidded GPU MSI 1060 6GB ARMOR OCV1 +335/+1000 RAM 16GB 2x8 Corsair Vengeance WLED 2400/3000 C14 COOLER Corsair H100i v1 BOARD MSI Z270 SLI SSD Samsung 960 Evo 250G, x3 2T Samsung 860 Evo HDD WDB 4T, WDB 1T PSU EVGA 650GQ80+M CASE Cougar PanzerS
CPU i7-10700k GPU MSI RTX 2080 Duke POS RAM 32GB 2x16 Corsair Dominator Platinum RGB 3200/3600 CL14 COOLER CM MasterLiquid ML360R RGB Push/Pull BOARD MSI MEG Z490 Ace SSD 980 Pro 500G, 860 Evo 1T PSU EVGA 1000P2 CASE Phanteks Enthoo Luxe TG Black
CPU Pentium G4600 GPU MSI GTX 1080 Armor OCV1 +100/+400 RAM 8GB 2x4 G.SKILL Aegis 2133/3000 CL16 COOLER Corsair H100i v1 BOARD MSI H110M Pro-VD-Plus SSD 860 Evo 1T HDD WDB 500G, WDB 1T PSU EVGA 430W Bronze CASE Deepcool Tesseract/ VIVO
SERVERS i5-3470, i5-3470, i5-4590 GPUS MSI 750Ti 4GB, BFG GTS 250 1GB, GTX 690 RAMS 3x 16GB 2x8 1866 C8 PSUS 2x EVGA 1000T2 COOLERS Stock, Stock, Custom Loop BOARDS Intel, Intel, EVGA Classified SSD x3 860 250G HDDS I don't care to list CASES Optiplex, Optiplex, 2000s Water Case
560HP/607TQ E85 198MPH2000 Audi S4 2.7Bi-Turbo with K04/RS6 Inlets SRM -  DAZ Tune - 2.8L N/A DOHC Heads  -APB Block - Mahle Pistions - JHM Racing H-beam Rods - TheTuner Manifolds - 3.5in to 3in Exhaust with Magnaflow Dual Box - Dual Titanium Exhaust Tips - SAI CNC Delete - S4 Modified Airbox - 85MM Maf- RS4 Intake Manifold p&p RS4 Y-pipe - RS4 Bi-pipes - RS4 Fuel Rail - A8 TTB - Billet Divertervalves - Silicone Hose Everything - SRMv4 Intercoolers - Clutch Fan Delete/Block off - Power Steering Light Pully - FluidAmper - Billet Cam gears - V8 Cam Bolts - ABS Relocate - VW Diesel Oil Pump
https://linustechtips.com/topic/927963-splitter-problem/#findComment-11352657
3 minutes ago, a7mddiaa said:
and also i changed my internet plan to 15mbps
can this affect the ping and stability?
?_? I think that is your problem.
https://linustechtips.com/topic/927963-splitter-problem/#findComment-11352679
11 minutes ago, a7mddiaa said:
what can i do about it?
Ask your ISP to up your speeds? Did you downgrade? If not, they aren't supposed to do that.
https://linustechtips.com/topic/927963-splitter-problem/#findComment-11352731
A cable splitter will cut the signal strength no matter if you use both sides. On top of that not all splitters are the same, some will not work with digital equipment.
https://linustechtips.com/topic/927963-splitter-problem/#findComment-11352853
