I Have An i7-7700HQ @ 2.8Ghz
My Question Is: After Redoing The Thermal Paste, I Am Seeing Tempertures On The Package Up To 85-90°C In Games Like PUBG.
However Each Core Is Running 60-70°C.
The Laptop Stays Hot And And Has A Sitting Temperture Of 53-61°C Idle.
Are These Temps Too High? And How Do I Keep Them Down?
Keep In Mind, I Live In Texas And It's 100°F Outside Right Now
https://linustechtips.com/topic/927714-help-with-a-cpu/
the ambient temp is not helping things.  and maybe you didnt get a good application?
Linux Daily Driver:
CPU: R5 2400G
Motherboard: MSI B350M Mortar
RAM: 32GB Corsair Vengeance LPX DDR4
HDD: 1TB POS HDD from an old Dell
SSD: 256GB WD Black NVMe M.2
Case: Phanteks Mini XL DS
PSU: 1200W Corsair HX1200
Gaming Rig:
CPU: i7 6700K @ 4.4GHz
Motherboard: Gigabyte Z270-N Wi-Fi ITX
RAM: 16GB Corsair Vengeance LPX DDR4
GPU: Asus Turbo GTX 1070 @ 2GHz
HDD: 3TB Toshiba something or other
SSD: 512GB WD Black NVMe M.2
Case: Shared with Daily - Phanteks Mini XL DS
PSU: Shared with Daily - 1200W Corsair HX1200
Server
CPU: Ryzen7 1700
Motherboard: MSI X370 SLI Plus
RAM: 8GB Corsair Vengeance LPX DDR4
GPU: Nvidia GT 710
HDD: 1X 10TB Seagate ironwolf NAS Drive.  4X 3TB WD Red NAS Drive.
SSD: Adata 128GB
Case: NZXT Source 210 (white)
PSU: EVGA 650 G2 80Plus Gold
https://linustechtips.com/topic/927714-help-with-a-cpu/#findComment-11350253
I Have Done Thermal Paste Before With No Problem. It Was Getting Temps A Lot Higher  Until I Redone It But I See Everywhere My Temps Are Supposed To Be About 60°C While Gaming.
https://linustechtips.com/topic/927714-help-with-a-cpu/#findComment-11350263
in a pc, not a laptop lol laptop sacrifice cooling for mobility
https://linustechtips.com/topic/927714-help-with-a-cpu/#findComment-11350274
Undervolt your CPU. With Intel Extreme Tuning Utility. That helps a lot. If you have good contact, you shouldn't go above 70-75 in games. But what you've told us leads me to believe that the contact between the heatsink and CPU isn't good or the thermal paste sucks. Because you should see a reduction, and idle temps shouldn't be above 45. And 85-90C spikes in games with those clocks with that CPU and new thermal paste? Way too high.
https://linustechtips.com/topic/927714-help-with-a-cpu/#findComment-11350279
I'm Using Arctic Silver 5 And I Dont See Any Issues With Mounting Of The Brackets
https://linustechtips.com/topic/927714-help-with-a-cpu/#findComment-11350285
Maybe not all cores have good contact? What's the average CPU temp when gaming with heavy CPU usage? Because if you hover around 70-75 on average, that's completely fine and you're doing good. I'd undervolt it still, if you haven't already. It helps a lot, 7700HQ doesn't need the voltage that 's applied to it from factory.
https://linustechtips.com/topic/927714-help-with-a-cpu/#findComment-11350297
It Stays Between 70-75 On Most Getting To 80-82 On Heavier Games. However, I Just Undervolted It -0.150 And It Seems Stable So After A 20 Minute Stress Test I Will Pull Up PUBG And See Where My Temps Are
https://linustechtips.com/topic/927714-help-with-a-cpu/#findComment-11350442
-150mv is pretty much max for 7700HQ. Do an extensive stress test and observe your laptop for any random crashes and bluescreens. But undervolting should greatly impact your temps.
I though my ran fine with -90mv (i7-4710HQ), because it didn't crash when stress testing. But it had random crashes and wasn't truly stable until I increased the voltage to -65mv. You'll see how it turns out for you, but kaby lake should do fine with -150mv offset.
https://linustechtips.com/topic/927714-help-with-a-cpu/#findComment-11350451
That Is Why I Am Using PUBG, It's A Pretty Hefty Title So It Tells Me Pretty Quick If It Is Going To Work
https://linustechtips.com/topic/927714-help-with-a-cpu/#findComment-11350457
Everything Is Solved Now, The Biggest Factor Was Ambient Temperture. I Have It Under Load Now At 55° Running At 3.6Ghz.
The Combination Of Ambient, Repaste, And Undervolting Dropped It 25°.
https://linustechtips.com/topic/927714-help-with-a-cpu/#findComment-11368944
