Help me find the perfect monitor
LiamGamer123
So i am looking for a high refresh rate 1080p or 1440p (prefer) budget monitor (<£200) hoping for around 27 inch
2 minutes ago, LiamGamer123 said:
i was maybe thinking of this one but that msi one is not too bad might go with that but what u think of this https://www.amazon.co.uk/LG-25UM58-inch-Ultrawide-Monitor/dp/B01BV1XB2K/ref=sr_1_1?ie=UTF8&qid=1526330006&sr=8-1&keywords=lg+ultrawide+monitor
dont get it. 25" ultrawides are a waste of money as they have significantly less screan area than a 25" 16:9.
how is that remotely possible
Remember that screens are measured by diagonal distance from corner to corner. If you had a square screen with 25" measurement, it would yield the most screen area. A very long and thin rectangle with the same diagonal would give you much less area.
