Hi Guys
So my Samsung Galaxy S8 Plus that i brought directly from their UK online store has been working a treat for the past year, recently it has been randomly crashing and restarting every couple of minutes and the battery would seem to drain in 2 minutes(it was like watching a timer count down from 100) then the moment it was connected to the charger it would register as having 100% battery and the screen would begin to flicker
after not realising, Re flashing stock firmware back over the top(Android Oreo apparently has some battery draining problems) and it making no difference.. The case on the phone popped off and it revealed that the glass back was being pushed away from the body from what looks to be the battery
Has anyone else had any issues with new Samsung phones (Post Note 7)?
IMG_0489.thumb.JPG.113c75b108815367b002fb1619a2fb06.JPGIMG_0491.thumb.JPG.70d772753e107daa624f27e79980d992.JPG
Thanks
Josh
(First Post BTW :) )
https://linustechtips.com/topic/926300-s8-plus-battery-swelling/
You need to get the battery replaced. Doing it on your own is possible, but it not really a thing.
Contact Samsung Customer Support.
*Insert meme about non-removable batteries here*
Laptop: 2024 16" MacBook Pro M4 Pro, 512GB, 48GB Unified Memory | Phone: iPhone 16 Pro Max 512GB | Wearables: Apple Watch SE | Car: 2025 Honda Accord SE & 2007 Ford Taurus SE | CPU: R7 5700X | Mobo: ASRock B450M Pro4 | RAM: 32GB 3200 | GPU: Sapphire Nitro+ 9070XT | Case: Fractal North | OS: Win 11 | Storage: 1TB Crucial P3 NVME SSD, 1TB PNY CS900, & 4TB WD Blue HDD | PSU: Seasonic Focus GX-850 | Display: LG 27GL83A-B 1440p @ 144Hz, Dell S2719DGF 1440p @144Hz | Cooling: Noctua NH-U12S | Keyboard: G610 Orion Cherry MX Brown | Mouse: G305 | Audio: Audio Technica ATH-M50X & Blue Snowball | Server: 2024 M4 Mac mini, 256GB SSD, 16GB Unified Memory | Storage: Terramaster D4-320 DAS (12TB Seagate Ironwolf Pro, 12TB Seagate Ironwolf, 6TB WD Blue HDD, 500GB Crucial SSD)
if you have original bill and since you bought it in the UK, you should have 24 months warranty. Just contact the store you bought it from, or see directly with samsung (uk?) if they know anything or can give you a replacement directly. Though usually you go via the store you bought it from for warranty coverage.
