I am looking for a cooler for my laptop that won't takes up much space and will cool my laptop (17-inch laptop) because I am planning to overclock my CPU which has integrated graphics (Hd Intel 5500) and my CPU is a dual-core i7 5500. I heard that vacuum coolers block the vent for your fan which is extremely bad for your fan and most cooling pads take up to much space on my 17 inches (width) desk and a length of about 35 - 40 inch (length). also I kind of need it at about around $1 - $15. I am willing to pay slightly more if necessary. Since I will have a USB keyboard for my laptop which takes up a good amount of desk space. Also, I do have a top/upper plank of wood on my desk that is about 35 inches in length and about 10 inches in width. which is where I am planning to put my pc on. So either a vacuum cooler that won't cover up much of my internal fan's mesh or a small cooling pad, either way, I need it to be able to withstand the heat of overclocking. (my CPU's max is 2.9 planning to reach 3.2 which should give a good boost in fps.)
And yes I have looked for over 3 hours and couldn't really find anything. I am hoping you guys will have better luck. as everyone has a different style of searching.   (Feel free to give me overclocking advice!)
Bethesda PC:   R7 3700X  -  Asrock B550 Extreme 4  -  Corsair Dominator Platinum RGB 16GB@3.6GHz -  Zotac AMP Extreme 1080TI -  Samsung 860 Evo 256GB  -  WD Blue 2TB SSD -  500DX  -  Stock cooling lul  -  Rm650x
CrumpleBox V3:  Xeon X5680  -  Asus X58 Sabertooth  -  DDr3 16GB@1.33Ghz  -  Gigabyte 1660s -  TT smart RGB 700W  -
Cooler Master Storm Trooper  -  120GB Samsung 850 Pro   -  LTT Edition Chromax NH-D15 ?
CrumpleBox 3 ROTF: I5-6400  -  MSI B150m Mortar  -  16GB 2133Mhz Vengeance Pro RGB  -  Strix 1070Ti - GTX 1070 FE  -  Adata 128GB SSD  -  Fractal Design Define C  -  Gammaxx 400V2  -  Cooler Master silent pro gold 1000W
CrumpleBox 2: i7-7820x - MSI X299 Raider - 32GB Thermaltake Toughram 3.6Ghz - 2x Sapphire Nitro Fury - 128GB PCie Adata SSD - O11 Dynamic - EVGA CLC 360 - Corsair RM1000X
Perhiperals:  Gateway 900p60 monitor  -  Dell 1024x768@75  -  Logi. G403 Carbon  -  Logi. G502  -  SteSer. Arctis 5  -  SteSer. Rival 110 - Corsair Strafe RGB MK.2
