So I have been wanting to get into water cooling for a while now but never really had the money for it. I currently have a corsair H60 cooling my 6850K but I have always wanted more than an AIO. So after looking at what custom loops cost I think I will be going with a kit to save some money. The kit I want to get is the EK fluid gaming A240 that Linus reviewed a while ago. It's not super expensive and will be relatively easy to add to later so long as I get aluminum parts. I am only doing the cpu for now as there is not a good block for my gpu other than some weird universal ones I would rather not use. I know that reviewers like Linus, Jayztwocents, and bitwit Kyle have given this kit good reviews, but I am wondering if anyone here has one that they have had in use for a long time and what they think about it. Also is there anything I should watch out for other than that it is all aluminum so don't mix metals.
Optical Drive Poll: https://linustechtips.com/main/topic/1006309-optical-drive-survey/
Main Rig (Redshift)
CPU: Ryzen 7 9800X3DX MOBO: MSI MAG X870E Tomahawk WIFI RAM: G.Skill Flare X5 (2x16gb) 6000MT/s 28-36-36-96 GPU: Sapphire NITRO+ 9070XT, Cooler: Noctua NH-D15 Chromax Storage:  Intel S3520 150gb x4 RAID0 for boot, Crucial P310 4tb x2 RAID0, MSI Spatium M470 1tb, SK Hynix Platinum P41 2tb,  Case: Phanteks Evolv X2 PSU: Seasonic Foucs GX 850W OS: Windows 11 Pro 64 bit
HexOS Server (Vault)
CPU: Xeon E5-2603v3 MOBO: MSI X99 Tomahawk RAM: G.Skill Aegis (4x8gb) 3000MT/s 16-18-18-38 GPU: Headless Cooler: Cooler Master Hyper 212 LED Storage: Intel S3520 150gb x2 for boot RAID1, x16 in RAIDZ1 for storage, LSI 9305-16i HBA,  Case: Phanteks Enthoo Pro Tempered Glass PSU: EVGA SupeNOVA G1+ 750W
https://linustechtips.com/topic/923932-first-custom-water-cooling-loop/
10 minutes ago, AdvancedMicroDisapointment said:
Probably just buy one of the Fluid Gaming Kits
https://www.ekfluidgaming.com/ek-kit-a240g
I most likely will just wanted to see if anyone owned one and what they thought of it.
Main Rig (Redshift)
It's a water cooling loop, they're all basically the same, that one will work fine.
5 hours ago, AdvancedMicroDisapointment said:
-SNIP-
For the GPU blocks they are limited to certain models so make sure you have a GPU that is compatible with the fluid gaming block:
https://www.ekwb.com/configurator/waterblock/3831109890769
I will sadly not be doing my gpu as I have an xfx rx 480 that does not have a specific block for it only weird universal ones that I do not want to use.
Main Rig (Redshift)
In that case you will have the option for loop expandability when you upgrade your system with more fluid gaming products/blocks that may come out in the future.
