I've got this laptop in november and since then it was all fine. About a month ago i started having problems playing more then 1-2 hours because my cpu was always around 90°-100° and started to throttle.
It got even worse this week since after i play 1 game of league of legends and i fire up fortnite(where i usually get around 150-190fps) i start getting 40 fps and my sound gets distorced
Edit: Yes i've cleaned the fans multiple times i think it might be a problem of thermal paste
Solved: undervolted the cpu but now i get power limit throttling that takes my cpu clock down by 1 ghz(from 3.4 to around 2.5-2.6)
https://linustechtips.com/topic/923466-dell-7577-overheating-problems/
If you live in the US then I would suggest changing out the thermal paste (US law says that you can work on your own things without voiding warranty as long as you don't damage it) to something like Gelid GC extreme. Undervolting the cpu will also help a bit, try doing both.
8086k Winner BABY!!
Main rig
CPU: R7 5800x3d (-25 all core CO 102 bclk)
Board: Gigabyte B550 AD UC
Cooler: Corsair H150i AIO
Ram: 32gb HP V10 RGB 3200 C14 (3733 C14) tuned subs
GPU: EVGA XC3 RTX 3080 (+120 core +950 mem 90% PL)
Case: Thermaltake H570 TG Snow Edition
PSU: Fractal ION Plus 760w Platinum
SSD: 1tb Teamgroup MP34  2tb Mushkin Pilot-E
Monitors: 32" Samsung Odyssey G7 (1440p 240hz), Some FHD Acer 24" VA
GFs System
CPU: E5 1660v3 (4.3ghz 1.2v)
Mobo: Gigabyte x99 UD3P
Cooler: Corsair H100i AIO
Ram: 32gb Crucial Ballistix 3600 C16 (3000 C14)
GPU: EVGA RTX 2060 Super
Case: Phanteks P400A Mesh
PSU: Seasonic Focus Plus Gold 650w
SSD: Kingston NV1 2tb
Monitors: 27" Viotek GFT27DB (1440p 144hz), Some 24" BENQ 1080p IPS
I live in Italy and i'm pretty sure it's not allowed. Is it normal to get these high temps or it might be a fault of dell? Can i ask for support?
You could try to send it in, but risk the chance of them sending it back saying that it isn't hitting tjmax of 105c. I guess trying wouldn't hurt, those temps are too high and will definitely reduce longevity.
8086k Winner BABY!!
Main rig
GFs System
QC issues like uneven heatsink and bad thermal paste job can happen. Try undervolting and repaste (Gelid GE Extreme). If not RMA it.
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
