Java Side Slider Issue #2
Go to solution Solved by Duda777,
I'm a noob a Javascript and have ran into a slight issue!
The issue starts from the two lines starting with "g2."
The error reads on line 107
Multiple markers at this line
- Syntax error on token "(", delete this token
- Syntax error on tokens, VariableDeclarator expected
instead
The error reads on line 108:
instead
Does the error say what is there instead of variable expected ?
The only thing I can think of is that the variable g2 has not been defined
And missing ; at the end
instead
instead
If someone could inbox me too as I need help with other coding!
private void update() {}	private void draw() {}	private void drawToScreen() {}		Graphics g2 = getGraphics();		g2.drawImage(image, 0, 0, null);		g2.dispose(image, 0, 0, null);					public void keyTyped(KeyEvent key) {}	public void keyPressed(KeyEvent key) {}	public void keyReleased(KeyEvent key) {}
https://linustechtips.com/topic/92324-java-side-slider-issue-2/
instead
instead
https://linustechtips.com/topic/92324-java-side-slider-issue-2/#findComment-1244033
Thanks!
https://linustechtips.com/topic/92324-java-side-slider-issue-2/#findComment-1244061
