8600k or 8700k would be optimal
CPU: INTEL Core i7 4790k @ 4.7Ghz - Cooling: NZXT Kraken X61 - Mobo: Gigabyte Z97X SLI - RAM: 16GB G.Skill Ares 2400mhz - GPU: AMD Sapphire Nitro R9 Fury 4G - Case: Phanteks P350X - PSU: EVGA 750GQ - Storage: WD Black 1TB - Fans: 2x Noctua NF-P14s (Push) / 2x Corsair AF140 (Pull) / 3x Corsair AF120 (Exhaust) - Keyboard: Corsair K70 Cherry MX Red - Mouse: Razer Deathadder Chroma
Bit of an AMD fan I suppose. I don't bias my replies to anything however, I just prefer AMD and their products. Buy whatever the H*CK you want.
---QUOTE ME OR I WILL LIKELY NOT REPLY---
https://linustechtips.com/topic/922987-cpu-selection-help/#findComment-11304344
8700 for both, with H or B chipset motherboard.
Desktop benching:
https://linustechtips.com/topic/922987-cpu-selection-help/#findComment-11304355
Ive just built a Ryzen 2700x system using a 1050ti and im quite happy with it.
MSI MAG X670E TOMAHAWK WIFI Motherboard, AMD Ryzen 9 7900X3D Desk-top Processor (12-core/24-thread, 140MB cache, up to 5.6 GHz max boost), CORSAIR VENGEANCE DDR5 RAM 32GB (2x16GB) 6000MHz CL30 AMD EXPO iCUE Compatible Computer Memory, Samsung 990 PRO NVMe M.2 SSD, 2 TB, PCIe 4.0, 7,450 MB/s read, 6,900 MB/s write, Internal SSD, 2 x Seagate BarraCuda 4 TB Internal Hard Drive HDD – 3.5 Inch SATA 6 Gb/s 5400 RPM 256 MB Cache for Computer Desktop PC Laptop (ST4000DM004), MSI MPG A1000G PCIE5 Power Supply Unit, UK Plug - 1000W, 80 Plus Gold Certified, Fully Modular ATX 3.0, PCIe 5.0 GPU, XILENCE XC982 LQ240PRO AIO COOLER, XFX Speedster MERC 310 AMD Radeon RX 7900 XT 20GB 1 x AOC CU34G2XE & 1 x Samsung U32J59XUQ 3840 x 2160 4K, 1 x Samsung Evo 970 Evo Plus NVME PCI-E 1TB, 1 x Samsung Evo 850 250GB, 1 X Sandisk Ultra II SSD 240GB + 2 X 4TB Seagate Barracuda SATA III,  MZHOU 7 Ports PCIe USB 3.0 Card,  2 x UGREEN Hard Drive Enclosure 3.5 inch External SATA Disk Caddy Reader USB 3.0 2.5 3.5 HDD SSD 16TB UASP Case Dock Station With 12V 2A Power Adapter For Windows with 6TB Seagate Barracuda SATA III, Fractal Design Pop XL Case + 4 Fractal Design 140mm Case Fans, Logitech MX Vertical & MX Ergo Trackball Mouse using same USB unifying device, Microsoft Ergonomic Keyboard, Windows 11 Pro x64 Retail, 6TB Seagate USB 3.0 Backup Plus Hub, Blue Yeti Microphone, Logitech C922 Pro HD,  Logitech C920 Pro HD, Bit Defender Total Security 2021.
Second PC (Cyclops) - MSI 990FXA Gaming, AMD FX 8370 4Ghz, Corsair 16GB Vengeance Red 9-9-9-24 1600Mhz, Arctic Cooling Freezer 13, Asus Strix 1050TI 4GB, 1 X Acer 27" Full HD Monitor, 1 X Sandisk Ultra II SSD 240GB, 1 x Samsung Evo 850 250GB, 2 X Seagate Barracuda 2TB, 1 X WD Black 2TB, 1 x ASUS 16x DVDRW, X-Case Eagle III Case, 3 X Corsair AF 120 Case Fans, EVGA 850 G2 80+ Gold + PSU, Logitech MX Master Mouse, Corsair K30 Keyboard, Logitech C920 Webcam, R0DE NT1-A Microphone, Scarlet 212 Audio Interface (Revision 2), Windows 10 Pro X64 Retail, Bit Defender Total Security 2021, 2TB Seagate Expansion USB Hard Drive.
Third PC (Old Trustie) - Acer Aspire M3400, OEM Mainboard, AMD FX Athlon II X3 425 2.7Ghz, 16GB Corsair Value 1600Mhz Ram, OEM CPU Cooler, AMD R7 260 2GB GPU, 1 X Acer 27" Full HD Monitor, 1 X Sandisk Ultra II SSD 240GB, 2TB Samsung SATA III, 1 X OEM 16X DVDRW, 1 X Acer OEM Case, 1 X Corsair AF120 Case Can, Corsair CX500 Bronze+ CPU, Logitech MX Master Mouse, Corsair K30 Keyboard, Windows 10 Home X64 OEM, Logitech C920 Webcam, Bit Defender Total Security 2021.
Printers Include - Canon MG5750, Canon, IP8750,  Canon Pixma Mega tank G5050 & 2 X Samsung Xpress C410W.
1 X Zexrow Xbox360 Wired Game Controller.
TP Link Archer AX6000 Cable Router Wifi6 with a Virgin Media Hub 4.0 in Modem only mode running 1GB Fibre internet.
Samsung Galaxy S21+ 256GB Mobile Phone.
Internet Speed.....
https://www.speedtest.net/result/9935039193
https://linustechtips.com/topic/922987-cpu-selection-help/#findComment-11304372
2 minutes ago, Josh2002 said:
Do you have any specific motherboard suggestions? I'm very new to building a PC not sure what mobo is good.
any requirements on number of ports and connectors? ATX, mATX or mITX?
Desktop benching:
https://linustechtips.com/topic/922987-cpu-selection-help/#findComment-11304427
@Josh2002 I used the Asus Crosshair Hero VII but the board itself is almost £250 so maybe over budget for u.
Internet Speed.....
https://linustechtips.com/topic/922987-cpu-selection-help/#findComment-11304451
Wow, that is expensive it's about $470 AUD, it also says it come with Wifi does this mean I won't need to buy the adapter aswell.
The one that I had added with a Intel i7-8700k was the Asus - ROG STRIX Z370-E GAMING ATX LGA1151 Motherboard - $300 AUD
Not sure if it's any good though, since I'm going to be waiting till July your suggestion will come down in price but it may not be good at that time.
Also, how do you have a 400 mbps, download speed, at best I get 1 mbps download.
Thanks
https://linustechtips.com/topic/922987-cpu-selection-help/#findComment-11304663
7 minutes ago, Josh2002 said:
I'm new to this so I dont know what any of that means, what do you think would be best?
ports: SATA ports (hard drives and some SSDs), USB, PS/2 (for old keyboards)
ATX, mATX and mITX all refer to size. mATX is the best value option, ATX looks better in a big case, mITX can fit in tiny cases.
Also do you need overclocking support? What CPU will be used?
Desktop benching:
https://linustechtips.com/topic/922987-cpu-selection-help/#findComment-11304668
I'll be going with the i7-8700k and I will need OC support.
https://linustechtips.com/topic/922987-cpu-selection-help/#findComment-11304671
Desktop benching:
https://linustechtips.com/topic/922987-cpu-selection-help/#findComment-11304705
Thanks
Yes with wifi u wont need a seperate adapter.
Internet Speed.....
https://linustechtips.com/topic/922987-cpu-selection-help/#findComment-11309452
