Vewsonic Xg2401 calibration help
2SPOOKY4ME
Just got an XG2401 and i need help with calibration.. I feel like the image is quite gloomy? Like the whites kinda hurt my eyes, and if i set it up in a different way I feel like it lacks contrast. Any help would be greatly appreciated
CPU: i5-8400 |  CPU COOLER: Cryorig H7 QUAD LUMI | MOBO: Gigabyte Z370M D3H RAM:  16gb Corsair Vengeance RGB 3200mhz CL15 |
GPU: Zotac GTX 1070 Mini @ +180/400 | Storage: Samsung 850 EVO 250gb, Western Digital Blue 2TB, Western Digital Green 1TB | Monitor: ViewSonic XG2401 144hz | Keyboard:  Corsair K70 Cherry MX RED Mouse: Zowie EC1-A
Try looking for colour profiles around the web. And choose the one you like the most.
I will send you mine once I get home (~8 hours). Unfortunately, I did not put the *.icm profile I have in a shared folder and cannot access it from University ?
CPU: Ryzen 7 5800X Cooler: Corsair H100i Platinum SE Mobo: Asus B550-A GPU: EVGA RTX 2070 XC RAM: G.Skill Trident Z RGB 3200MHz 16CL 4x8GB (DDR4) SSD0: Crucial MX300 525GB SSD1: Samsung QVO 1TB PSU: NZXT C650 Case: Corsair 4000D Airflow Monitor: Asus VG259QM (240Hz)
I usually edit my posts immediately after posting them, as I don't check for typos before pressing the shiny SUBMIT button.
Unraid Server
CPU: Ryzen 5 7600 Cooler: Noctua NH-U12S Mobo: Asus B650E-i RAM: Kingston Server Premier ECC 2x32GB (DDR5) SSD: Samsung 980 2x1TB HDD: Toshiba MG09 1x18TB; Toshiba MG08 2x16TB HDD Controller: LSI 9207-8i PSUCorsair SF750 Case: Node 304
First, check the monitor settings (to make sure no "enhancements" are applied.), then:
https://www.google.ca/url?sa=t&source=web&rct=j&url=%23&ved=0ahUKEwi9p9-egufaAhVokuAKHVmXBB4Qxa8BCCUwAA&usg=AOvVaw0VTJzWxrN8ZFOD4xbU2nov
Since I am to lazy to put something interesting here, I will put everything, but slightly abbreviated. Here is everything:
42
also, some questions to make you wonder about life:
What is I and who is me? Who is you? Which armrest in the movie theatre is yours?
also,
Welcome to the internet, I will be your guide. Or something.
My build:
CPU: Intel Core i5-7400 3.0GHz Quad-Core Processor,
 Motherboard: ASRock B250M Pro4 Micro ATX LGA1151 Motherboard,
Memory: Corsair 8GB (1 x 8GB) DDR4-2133 Memory,
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive,
Video Card: MSI Radeon RX 480 4GB ARMOR OC Video Card,
Case: Corsair 100R ATX Mid Tower Case ,
Power Supply: Corsair CXM 450W 80+ Bronze Certified Semi-Modular ATX Power Supply,
Operating System: Microsoft Windows 10 Home Full,
Wireless Network Adapter: TP-Link TL-WN725N USB 2.0 802.11b/g/n Wi-Fi Adapter, Case Fan: Corsair Air Series White 2 pack 52.2 CFM  120mm Fan
ou do not ask why, you ask why not -me
Remeber kinds, the only differ between screwing around and scince is writing it down. -Adam Savage.
Only two things are infinite: the universe and human stupidity, and I'm not even sure of the former. - Albert Einstein.
I've had a few settings and tweaked it a bit to my liking, i've felt that a lot of the icc profiles i tried made it more gloomy than rich. I'm on the default XG2401 profile right now with.
Contrast 62, brightness 75, r 95 g 92 b 100, sharpness 75, black eq 5, dcr 0, response time advanced, low input lag ultra fast, dcr 0. On a default icc profile
But thanks a bunch! I'm willing to wait for you to share ur settings and icc profile :D any improvements are welcome!
Everything is on standard and have set a user profile for my color settings, actually everything looks pretty good right now but i'm open to improvements. :D (btw link doesn't work)
