What do you mean it wont connect?
Do you have a GPU and a monitor with a HDMI connection on them?
PC SYSTEM: Fractal Design Arc Midi R2 / i5 2500k @ 4.2ghz / CM Hyper 212 EVO / Gigabyte 670 OC SLI / MSI P67A-GD53 B3 / Kingston HyperX Blue 8Gb /
WD 2tb Storage Drive / BenQ GW2750HM - ASUS VE248H - Panasonic TX-P42ST60BCorsair AX750 / Logitech K360 / Razer Naga / Plantronics Gamecom 380 /
Asus Xonar DGX / Samsung 830 256gb / MEDIA eMachine ER1401 running OpenELEC XBMC with Seagate STBV3000200 3TB Hard Drive - Panasonic TX-P42ST60B
https://linustechtips.com/topic/92257-need-help/#findComment-1242962
so i built a computer and everything from what i see works fine except for that it doesn't connect to the monitor i have with a hdmi cable. How do i fix this?
DVI cable. What gpu and monitor do you have?
Rig: i7 2600K @ 4.2GHz, Larkooler Watercooling System, MSI Z68a-gd80-G3, 8GB G.Skill Sniper 1600MHz CL9, Gigabyte GTX 670 Windforce 3x 2GB OC, Samsung 840 250GB, 1TB WD Caviar Blue, Auzentech X-FI Forte 7.1, XFX PRO650W, Silverstone RV02 Monitors: Asus PB278Q, LG W2243S-PF (Gaming / overclocked to 74Hz) Peripherals: Logitech G9x Laser, QPad MK-50, AudioTechnica ATH AD700
https://linustechtips.com/topic/92257-need-help/#findComment-1242965
Are you using on board graphics, meaning from the motherboard, or from a video card?
AMD FX-8350 Asus M5A-99X R2.0 EVO Corsair Vengeance 8GB DDR3 (9-9-9-24 @1600MHz) - Gigabyte Radeon HD 7970 (OC 1000MHz) - Corsair TX-650
Corsair H100i Fractal Design R4 Razer Black Widow Ultimate 2013 MadCatz R.A.T. 7 WD Caviar Black 2TB and Samsung 840 120GB
==="Train yourself to let go of everything you fear to lose" ~ Master Yoda===
https://linustechtips.com/topic/92257-need-help/#findComment-1243031
What are your  specs? Do you have a video card?
Life is pain. Anyone who says any different is either selling something or the government.
----CPU: FX-6300 @ 4.2ghz----COOLER: Hyper 212 EVO----MOBO: MSI 970A-G46----PSU: OCZ 600watt----CASE: Black Corsair C70----GPU: Sapphire 7870 dual fan ghz edtion----2 random HDD'S----A couple fans here and there. Mouse: Gigabyte M6900-------Keyboard: Logitech G105-----Mousepad: Steel series something something.
https://linustechtips.com/topic/92257-need-help/#findComment-1243049
video card
Do you have the option to run the graphics from the motherboard?  If you do... and assuming it does post where you could see everything, download the latest driver for the video card.  Then install it and re-seat the card.  If you do not have on-board graphics or you are unable to install the driver with the card not detected, just simply try re-seating the card.  Also try a different PCI-Express slot. :)
https://linustechtips.com/topic/92257-need-help/#findComment-1243999
Try removing the GPU then plugging it into the output on your motherboard if you have the option because sometimes the motherboard will disable the GPU unless explicitly enabled in the BIOS. If that works, go into your BIOS and look for a setting like "disable iGPU", and turn it on if it exists. Then try replacing your GPU and rebooting. Also, do you have any option to use any other cable type, just in case it's a problem with the HDMI cable/ports/drivers (don't go any buy anything just to check).
HTTP/2 203
https://linustechtips.com/topic/92257-need-help/#findComment-1244719
