Graphics card stuck at 139mhz - Please help!
Solved by Grimm_,
1 hour ago, Eibe said:The GPU underclocks itself when idling... You should take a screenshot with a game running in the background (windowed mode).
Anyway, uninstall the drivers with DDU and reinstall them (maybe not the latest ones as I have heard problems with the latest GeForce drivers).
41 minutes ago, star_weaver said:tried a computer restart?
I appreciate the time you guys took to help me, but i found the solution. Seems like my GPU cable somehow is broke. i put the new one in and i'm not playing at almost 300fps at normal speeds.
Thanks again
