Huawei HG658 VoIP/Telephone Bridging Problem
Hello,
How can I enable the VoIP/Telephone function in this ISP provided device without using it as a modem? Normally the DSL cable needs to be connected in the back for the device to connect to the server.
https://imgur.com/a/nKbgGwQ
Is there a way to set a new WAN connection that can bridge the link required for the VoIP feature through the DSL or one of the LAN/Ethernet ports (as a client)? The LAN Grouping option can then be used to bind the new connection to the required port (fourth image in the album).
Thank you.
