I want to get the ROG Strix 1080 TI and I'm really thinking if it's actully any better
Budget is not a problem so I am just asking
I considered it cause it has three fans on the top and I'm gonna stress whatever I get so the cooling needs to be to the max
That's why I also bought 5 Corsair 140 mm pro magnetic led fans for my case
https://linustechtips.com/topic/922371-sooooo-i-need-help/
Better than what?
The Asus Strix 1080ti is arguably one of the best cards on the market at the moment.
https://linustechtips.com/topic/922371-sooooo-i-need-help/#findComment-11298318
5 minutes ago, Mihh said:
and also is an 1080 TI better than 1080 SLI cuz just wondering
Performance, 1080 SLI is better. Value and efficiency, a single 1080ti is much much better.
better than other 1080 TI cause of the cooling
Unless you go liquid, only the EVGA Kingpin and MSI Lightning card can beat the Strix in cooling performance. It's similar to EVGA's FTW3, Galax/KFA2 HOF and Aorus Xtreme in cooling and noise.
Desktop benching:
https://linustechtips.com/topic/922371-sooooo-i-need-help/#findComment-11298328
3 hours ago, Mihh said:
ok thanks
made an account just to ask this
Would get any evga 1080 ti (cheapest one) and put an arctic accelero xtreme iv on it. Superior to any custom modell and evga covers a cooler change in their warranty. It will cool better and be less noisy than strix, kingpin and any other aircooled card.
https://linustechtips.com/topic/922371-sooooo-i-need-help/#findComment-11298603
