alright, I start my job next week and I finally put together a PC that I can afford in the next several weeks.
CPU: Intel - Core i5-8400 2.8GHz 6-Core Processor  ($178.99 @ Amazon)
Motherboard: Gigabyte - B360 HD3 ATX LGA1151 Motherboard  ($84.99 @ SuperBiiz)
Memory: Team - Vulcan 16GB (2 x 8GB) DDR4-2400 Memory  ($149.99 @ Newegg)
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($59.79 @ OutletPC)
Video Card: KFA2 - GeForce GTX 780 Ti 2GB OC Video Card
Case: Cougar - MX330 ATX Mid Tower Case  ($24.99 @ SuperBiiz)
Power Supply: Corsair - CXM 550W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($64.89 @ OutletPC)
Total: $563.64
Generated by PCPartPicker 2018-04-30 10:27 EDT-0400
https://linustechtips.com/topic/922142-first-build/
Memory: Team - Elite Plus 8GB (1 x 8GB) DDR4-2400 Memory
Total: $413.65
Generated by PCPartPicker 2018-04-30 10:25 EDT-0400
Do u already HV the 780ti??
SSD TIER LIST
CPU - Ryzen 7 3700X
Mobo - ASRock X470 Taichi
Memory - G.Skill Trident Z RGB (8x2 3200MHz)
Storage - Sabrent Rocket 1TB - Seagate Barracuda 2TBWD Black 1TB
GPU - MSI GeForce GTX 980Ti LIGHTNING
CaseFractal Design Meshify C
PSUSuper Flower Leadex II Gold 650W
https://linustechtips.com/topic/922142-first-build/#findComment-11295694
2 minutes ago, LixCoffee said:
no but it would be around 100-150$ from couple sources
BUILD SOMETHING LIKE THIS.....
Motherboard: ASRock - B360M Pro4 Micro ATX LGA1151 Motherboard  ($87.31 @ Newegg)
Memory: Team - T-Force Delta RGB 16GB (2 x 8GB) DDR4-3000 Memory  ($159.99 @ Newegg)
Storage: Crucial - MX500 250GB 2.5" Solid State Drive  ($69.99 @ Adorama)
Video Card: KFA2 - GeForce GTX 780 Ti 2GB OC Video Card  ($150.00)
Case: Cooler Master - MasterBox Q300L MicroATX Mini Tower Case  ($38.99 @ SuperBiiz)
Power Supply: Cooler Master - MasterWatt 550W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($34.65 @ Newegg)
Total: $779.71
Generated by PCPartPicker 2018-04-30 10:30 EDT-0400
SSD TIER LIST
CPU - Ryzen 7 3700X
https://linustechtips.com/topic/922142-first-build/#findComment-11295705
yeah man you need an SSD. it's just 60 bucks more and it's a game changer the rest is up to your preferences. I'd recommend a k SKU CPU even thought it's much more expensive because it will be much easier to resell at a much higher price. it will still be worth over 200$ 3 years later (as far as history servers)
Primary System
  • CPU
    Ryzen R6 5700X
  • Motherboard
    MSI B350M mortar arctic
  • RAM
    32GB Corsair RGB 3600MT/s CAS18
  • GPU
    Zotac RTX 3070 OC
  • Case
    kind of a mess
  • Storage
    WD black NVMe SSD 500GB & 1TB samsung Sata ssd & x 1TB WD blue & x 3TB Seagate
  • PSU
    corsair RM750X white
  • Display(s)
    1440p 21:9 100Hz
https://linustechtips.com/topic/922142-first-build/#findComment-11295739
U need to keep an eye if a person is on a budget or not......the 'k' varient of processors r probably gonna cost more.....also u'll need a decent cooler along with it.....ND u'll HV to get a z370 board to take full advantage of that 'k' series chip...
I agree with you that it has better resale value.....but I hope u get my point...
SSD TIER LIST
CPU - Ryzen 7 3700X
https://linustechtips.com/topic/922142-first-build/#findComment-11295815
An SSD is NOT a need.  I still don't have one I am just fine in everything I do on the pcs I use.
https://linustechtips.com/topic/922142-first-build/#findComment-11295852
Get an SSD then...... u'll notice a significant improvement in boot times ND loading times....
SSD TIER LIST
CPU - Ryzen 7 3700X
https://linustechtips.com/topic/922142-first-build/#findComment-11295909
i mourn for you too.......
jokes aside of course your fucking fine with everything you do. it doesn't prevent you from doing anything. it's just excruciatingly slow. before ssd's became wide spread storage was the single biggest bottleneck in a system since the dawn of computers.... but in this day and age there is no excuse for not having one, it's as if you had a 10 year old CPU you where buying today for a new system and you'd be buying it new at MSRP. that's preposturous
Primary System
  • CPU
    Ryzen R6 5700X
  • Motherboard
  • RAM
  • GPU
    Zotac RTX 3070 OC
  • Case
    kind of a mess
  • Storage
  • PSU
  • Display(s)
    1440p 21:9 100Hz
https://linustechtips.com/topic/922142-first-build/#findComment-11296131
yes and yes but not necessarily having to overclock. because somebody that's too shy to do it anyway still gets a bit of performance and gains allot on the resale so the current cost is higher but you get more at the end 3 years down the line. making the future upgrade cost less. of course if you can't afford it don't buy it, i'm sorry if my common sense forgets to mention that part...
it's just a suggestion as a thing to keep in mind because the price difference of the product stack does not stay the same over time. the ones that have less apparent value drop allot while the ones people look for later on hoping to juice out every bit of performance have keep much more of their value. and that's completely besides the point of the performance you have while you are using the chip.
to me it's worth the price premium not because i can overclock it, but because i can sell it back down the line and the difference from the k to non k then is bigger than it is now when i buy it. so i saved myself money on my new system.
but for that i'm also taking into account that i KNOW i will sell it and I KNOW i will buy a new system. some people stay with their machine for 5~6 maybe even 7 years. if that's your plan then don't do this. the computer's perceived value at that point is barely worth scraps. if you pull 100 or 110$ at that point will depend more on your bargaining abilities than what the specs are.
Primary System
  • CPU
    Ryzen R6 5700X
  • Motherboard
  • RAM
  • GPU
    Zotac RTX 3070 OC
  • Case
    kind of a mess
  • Storage
  • PSU
  • Display(s)
    1440p 21:9 100Hz
https://linustechtips.com/topic/922142-first-build/#findComment-11296164
I5 8600k at the current date costs $239.99....
How how can u expect to get over $200 after 2 years......
SSD TIER LIST
CPU - Ryzen 7 3700X
https://linustechtips.com/topic/922142-first-build/#findComment-11296479
Thanks for considering Seagate! Feel free to reach out if you have any questions on the HDD.
Seagate Technology | Official Forums Team
IronWolf Drives for NAS Applications - SkyHawk Drives for Surveillance Applications - BarraCuda Drives for PC & Gaming
https://linustechtips.com/topic/922142-first-build/#findComment-11297081
just wanna let you know im not looking to overclock.... So getting a better cooler and spending more money on a MOBO wouldn't be worth it.
also upgrading my processor wouldn't be helpful for me anyways..... overclocking is meh to me. Im fine with out of box.
https://linustechtips.com/topic/922142-first-build/#findComment-11299104
4 minutes ago, LixCoffee said:
Without investing in full-blown SSD, a hybrid like our FireCuda can be a great solution for getting both faster boot times and bang-for-your-buck storage capacity. The drive works by taking which data you access most frequently as you use it more and more, and placing that on the SSD cache portion for performance. The particular FireCuda you've listed is a 2.5", 5400 RPM version. There is also a 3.5", 7200 RPM version which may be a better fit as it will be faster. It doesn't come in 500GB capacity, but the 1TB capacity should be somewhere around close to the price range of the 2TB BarraCuda originally listed.
https://linustechtips.com/topic/922142-first-build/#findComment-11299166
FYI, there is no 780Ti 2GB. The 780Ti is a 3GB card. Must be a typo or a fake card (likely a 680 in disguise :P )
PC Specs - AMD Ryzen 7 5800X3D MSI B550M Mortar - 32GB Corsair Vengeance RGB DDR4-3600 @ CL16 - ASRock RX7800XT 660p 1TBGB & Crucial P5 1TB Fractal Define Mini C CM V750v2 - Windows 11 Pro
https://linustechtips.com/topic/922142-first-build/#findComment-11299200
1 minute ago, LixCoffee said:
Whats the difference between and 5400rpm and 7200rpm I understand at the minimum its faster but don't really know what the meaning of it is.
7200RPM is faster.  RPM stands for rotations per minute.  A hard drive is spinning disks and a needle that reads them, similar to a record player, but it's magnetic.  The faster it spins, the faster it can access the data.
Make sure to quote or tag me (@JoostinOnline) or I won't see your response!
PSU Tier List  |  The Real Reason Delidding Improves Temperatures"2K" does not mean 2560×1440
https://linustechtips.com/topic/922142-first-build/#findComment-11299298
10 minutes ago, LixCoffee said:
is it a huge difference like extremely noticeable?
Depends on what you're doing. For accessing you Operating System & loading applications, it can feel like quite a difference. If it's just extra storage for your photos, music, stuff you just need to maximize TB's of storage space for, it may not be seen as all that noticeable. This also depends on the individual user and what you're used to. What you consider a noticeable difference could be either more or less than what I consider a noticeable difference. If you want a more nuts-and-bolts comparison, here are a few max sustained transfer rates of our models for example (with linked spec sheets):
2TB, 2.5", 5400 RPM BarraCuda: up to 140 MB/s (Megabytes per second)
2TB, 3.5", 7200 RPM BarraCuda: up to 210 MB/s
https://linustechtips.com/topic/922142-first-build/#findComment-11299352
Honestly everything depends on your budget and your intended use. Overall an SSD or a hybrid drive make most sense as an investment. If you set your budget, use scenario, and where you're buying the parts it'll be easier to recommend parts.
AMD Ryzen 3950x under a Noctua D15S, 32 Gb G Skill FlareX 3200 DDR4 running at 3200 CL14, Gigabyte Aorus Pro 570 Wifi, Gigabyte 2070 Super hooked to a Dell U2718Q 4k HDR monitor & an Acer 1440p 144hz IPS panel of some kind, an Inland 1 TB M.2 PCIE 4 main drive, a Samsung NVME M.2 250Gb, WD Blue 500Gb  and 1 TB SSDs, Corsair RMX750, Rainbows and butterflies...
https://linustechtips.com/topic/922142-first-build/#findComment-11299383
sorry i was thinking in canadian roopies
Primary System
  • CPU
    Ryzen R6 5700X
  • Motherboard
  • RAM
  • GPU
    Zotac RTX 3070 OC
  • Case
    kind of a mess
  • Storage
  • PSU
  • Display(s)
    1440p 21:9 100Hz
https://linustechtips.com/topic/922142-first-build/#findComment-11299893
