Hey, I am looking for a 13" macbook pro replacement that can game. I am mostly playing PUBG/Squad. I want something portable as I travel a lot for work. I do not want to break the  bank and I am in Canada. I think my largest priority is size.
The 3 I was looking at were:
MSI GS65 Stealth Thin
Razer Blade
Asus zephyrs 501m.
All of these laptops are a bit on the expensive side.
Thanks for any input!
https://linustechtips.com/topic/921669-help-purchasing-a-laptop/
What kind of games?
Laptop: 2024 16" MacBook Pro M4 Pro, 512GB, 48GB Unified Memory | Phone: iPhone 16 Pro Max 512GB | Wearables: Apple Watch SE | Car: 2025 Honda Accord SE & 2007 Ford Taurus SE | CPU: R7 5700X | Mobo: ASRock B450M Pro4 | RAM: 32GB 3200 | GPU: Sapphire Nitro+ 9070XT | Case: Fractal North | OS: Win 11 | Storage: 1TB Crucial P3 NVME SSD, 1TB PNY CS900, & 4TB WD Blue HDD | PSU: Seasonic Focus GX-850 | Display: LG 27GL83A-B 1440p @ 144Hz, Dell S2719DGF 1440p @144Hz | Cooling: Noctua NH-U12S | Keyboard: G610 Orion Cherry MX Brown | Mouse: G305 | Audio: Audio Technica ATH-M50X & Blue Snowball | Server: 2024 M4 Mac mini, 256GB SSD, 16GB Unified Memory | Storage: Terramaster D4-320 DAS (12TB Seagate Ironwolf Pro, 12TB Seagate Ironwolf, 6TB WD Blue HDD, 500GB Crucial SSD)
@TLCH723 - So what are you trying to say to point me in a direction?
@NumLock21 - I will look into them, Are they supposed to be super portable?
@DrMacintosh - PubG and Squad right now... going forward newer games that come out?
Anyone else have any input?
Do you need battery life? If not get the GM501.
If you are not going to upgrade, then get the GS65. (Still waiting for review)
All gaming laptops at this size suffer heat.
As @ZM Fong will say
Quote
Buy from resellers that offers repaste like gentechpc and HIDevolution.
4 hours ago, ILiketoMobit said:
get the aero 15x v8
Runs too hot. Needs LM repaste, otherwise not recommended.
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
21 hours ago, NumLock21 said:
I know that's the weight. Op says they are too expensive, the 3 models in op's post.
Oh, you quoted me. And then you said is getting cheap so I was confused.
5 hours ago, ILiketoMobit said:
get the aero 15x v8
Do you work for gigabyte or something? You keep recommending this computer
Maybe LM is not enough. Mine should have come with LM but still run hot (putting on reseller truth). Still need to do more testing. Did basic stress test and update drivers and windows. Now going to reformat the computer to see if it will make a difference.
btw, people use throttle and not at turbo interchangeably. In my book, throttle mean running below based clock and not at turbo run somewhere between base clock and the max turbo
That guy knows nothing about laptops so just ignore what he had said
OK this is interesting. Mind providing some pictures about CPU+GPU temps and clock speeds in NBC style Prime95+Furmark load?
There are many types of throttling too. Thermal, EC firmware, power limit etc.
Desktop specs:
