Razer core in Desktop using Quadro?
Solved by Electronics Wizardy,
2 hours ago, arifoxs said:i just want to know about the use of razer core on desktop pc is it possible?
yes it works fine.
What psu do you have? Quadros are normally pretty low power.
Normally a faster gpu is a better opion here, not a core. ANd a lot cheaper.
What are you doing, vray renering isn't anyfaster on a quadro, and a high end geoforce is much better here.
