1 minute ago, Yoyohoneywasp said:
I dont know why but my gpu keeps overheating I removed the overclock and revert it back to its oem configuration.
Are the fans working? Is the card caked with dust? Is the case getting decent airflow?
https://linustechtips.com/topic/919822-overheating/#findComment-11273627
Also, NVIDIA GPUs typically designed to as fast as possible until it hits what it thinks is a thermal limit, then it adjusts itself if it thinks the cooling system can't keep up. But unless it starts dropping below the base clock speed, it's not considered to be in a thermal throttling condition.
https://linustechtips.com/topic/919822-overheating/#findComment-11273672
I have a AMD GPU. If my card is constantly at full clock speed, is this a good thing?
https://linustechtips.com/topic/919822-overheating/#findComment-11273726
Unless you deliberately want it that way, no. It's supposed to lower clock speeds if idling.
https://linustechtips.com/topic/919822-overheating/#findComment-11273731
