im building my first pc and i was looking to spend about £1000 (gbp) on it and iv made a pc part picker for it and have no compatibility issues. im hoping to start off with a ok build that i can upgrade over time to make a enthusiast build is this a good start if not let me know what some better options are.(this is for gaming and game coding) im going to start with 2 monitors and upgrade to 3 at some point (i already have 2 so im spending nuthing on it) i have the keyboard and a basic mouse im going to use for now
https://pcpartpicker.com/list/7m48J8 (im going to upgrade to 2x8gb of ram after its working and im also going to add a ssd)
specs incase you dont want to click the link:
intel core i5 8600k
corsair h100i
asrock z370 extreme4
crucial balistix sport lt 8gb(will get another 8gb stick when the pc works)
seagate baracuda 2tb 7200 rpm(already have it) (im going to get a ssd or m.2 after the pc is up and running)
pny nvidea geforce 1060 6gb oc
cooler master haf x
tp link TL-WDN4800 N900
antec Nano Diamond Thermal Compound
corsair CP-9020091-UK RM650x 650 W 80 Plus Gold
https://linustechtips.com/topic/919704-pc-build-help/
Nonononono not the 7400. Even the last gen AMD R5 1400 beats out that.
I'd change... many thing.
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/919704-pc-build-help/#findComment-11272450
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  (£134.99 @ Aria PC)
CPU Cooler: ARCTIC - Freezer 13 Limited Edition 4.0 CFM CPU Cooler  (£28.93 @ Novatech)
Motherboard: MSI - B350 TOMAHAWK ATX AM4 Motherboard  (£80.99 @ Ebuyer)
Memory: Team - T-Force Delta RGB 16GB (2 x 8GB) DDR4-2400 Memory  (£149.99 @ Overclockers.co.uk)
Storage: Samsung - 850 EVO-Series 250GB 2.5" Solid State Drive  (£77.50 @ Amazon UK)
Storage: Seagate - BarraCuda Pro 5TB 3.5" 7200RPM Internal Hard Drive  (£167.10 @ Amazon UK)
Video Card: PNY - GeForce GTX 1060 6GB 6GB XLR8 Gaming OC Video Card  (£247.58 @ Amazon UK)
Case: Thermaltake - Versa H21 Window ATX Mid Tower Case  (£36.99 @ Amazon UK)
Power Supply: BitFenix - Whisper M 450W 80+ Gold Certified Fully-Modular ATX Power Supply  (£74.99 @ Overclockers.co.uk)
Wireless Network Adapter: Asus - PCE-N15 PCI-Express x1 802.11b/g/n Wi-Fi Adapter  (£12.90 @ Ebuyer)
Case Fan: Cooler Master - MasterFan Pro 120 Air Balance RGB 42.7 CFM  120mm Fan  (£12.95 @ Overclockers.co.uk)
Total: £1037.86
Generated by PCPartPicker 2018-04-23 18:00 BST+0100
This is what I'm personally building. You can switch out the A320 board for a B450 board if you want but I've already got the board (bought it months ago along with case). Bought A320 because zen won't need overclocking for ages. I also have a HDD that I can use myself too.
EDIT: Added a HDD and an overclockable mobo for you. Mobo should be compatible so long as they don't send you older stock (by now most of the incompatible stock has gone).
There are 10 types of people in this world. Those that understand binary and those that don't.
Current Rig (Dominator II): 8GB Corsair Vengeance LPX DDR4 3133 C15, AMD Ryzen 3 1200 at 4GHz, Coolermaster MasterLiquid Lite 120, ASRock B450M Pro4, AMD R9 280X, 120GB TCSunBow SSD, 3TB Seagate ST3000DM001-9YN166 HSD, Corsair CX750M Grey Label, Windows 10 Pro, 2x CoolerMaster MasterFan Pro 120, Thermaltake Versa H18 Tempered Glass.
Previous Rig (Black Magic): 8GB DDR3 1600, AMD FX6300 OC'd to 4.5GHz, Zalman CNPS5X Performa, Asus M5A78L-M PLUS /USB3, GTX 950 SC (former, it blew my PCIe lane so now on mobo graphics which is Radeon HD 3000 Series), 1TB Samsung Spinpoint F3 7200RPM HDD, 3TB Seagate ST3000DM001-9YN166 HDD (secondary), Corsair CX750M, Windows 8.1 Pro, 2x 120mm Red LED fans, Deepcool SMARTER case
My secondary rig (The Oldie): 4GB DDR2 800, Intel Core 2 Duo E8400 @ 3GHz, Stock Dell Cooler, Foxconn 0RY007, AMD Radeon HD 5450, 250GB Samsung Spinpoint 7200RPM HDD, Antec HCG 400M 400W Semi Modular PSU, Windows 8.1 Pro, 80mm Cooler Master fan, Dell Inspiron 530 Case modded for better cable management. UPDATE: SPECS UPGRADED DUE TO CASEMOD, 8GB DDR2 800, AMD Phenom X4 9650, Zalman CNPS5X Performa, Biostar GF8200C M2+, AMD Radeon HD 7450 GDDR5 edition, Samsung Spinpoint 250GB 7200RPM HDD, Antec HCG 400M 400W Semi Modular PSU, Windows 8.1 Pro, 80mm Cooler Master fan, Dell Inspiron 530 Case modded for better cable management and support for non Dell boards.
Retired/Dead Rigs: The OG (retired) (First ever PC I used at 3 years old back in 2005) Current Specs: 2GB DDR2, Pentium M 770 @ 2.13GHz, 60GB IDE laptop HDD, ZorinOS 12 Ultimate x86. Originally 512mb DDR2, Pentium M 740 @ 1.73GHzm 60GB IDE laptop HDD and single boot XP Pro. The Craptop (dead), 2gb DDR3, Celeron n2840 @ 2.1GHz, 50GB eMMC chip, Windows 10 Pro. Nightrider (dead and cannibalized for Dominator II): Ryzen 3 1200, Gigabyte A320M HD2, 8GB DDR4, XFX Ghost Core Radeon HD 7770, 1TB Samsung Spinpoint F3 (2010), 3TB Seagate Barracuda, Corsair CX750M Green, Deepcool SMARTER, Windows 10 Home.
https://linustechtips.com/topic/919704-pc-build-help/#findComment-11272466
Motherboard: Gigabyte - GA-A320M-HD2 Micro ATX AM4 Motherboard  (£41.99 @ Ebuyer)
Total: £794.77
Generated by PCPartPicker 2018-04-23 17:47 BST+0100
Andddd
some of those parts aren't available in US AFAIK
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/919704-pc-build-help/#findComment-11272470
2 minutes ago, JDE said:
Andddd
He said GBP...
https://linustechtips.com/topic/919704-pc-build-help/#findComment-11272481
2 minutes ago, xriqn said:
He said GBP...
Ah. Didn't see that part since he used PCPP US.
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/919704-pc-build-help/#findComment-11272490
Yeah I think he's used the wrong PCPP.
https://linustechtips.com/topic/919704-pc-build-help/#findComment-11272493
PCPartPicker part list: https://uk.pcpartpicker.com/list/8xJzNQ
Price breakdown by merchant: https://uk.pcpartpicker.com/list/8xJzNQ/by_merchant/
CPU: AMD - Ryzen 5 2600X 3.6GHz 6-Core Processor  (£192.95 @ AWD-IT)
Motherboard: Gigabyte - X470 AORUS ULTRA GAMING ATX AM4 Motherboard  (£126.99 @ Box Limited)
Memory: G.Skill - Trident Z 16GB (2 x 8GB) DDR4-3000 Memory  (£148.40 @ More Computers)
Storage: Crucial - MX500 500GB 2.5" Solid State Drive  (£106.68 @ More Computers)
Video Card: Zotac - GeForce GTX 1060 3GB 3GB Mini Video Card  (£199.99 @ Overclockers.co.uk)
Case: Phanteks - Eclipse P300 Tempered Glass ATX Mid Tower Case  (£47.94 @ Aria PC)
Power Supply: Corsair - RMx 550W 80+ Gold Certified Fully-Modular ATX Power Supply  (£82.99 @ Amazon UK)
Operating System: Microsoft - Windows 10 Home OEM 64-bit  (£79.99 @ AWD-IT)
Total: £985.93
Generated by PCPartPicker 2018-04-23 17:56 BST+0100
https://linustechtips.com/topic/919704-pc-build-help/#findComment-11272498
Total: £985.93
Bad video card, not worth it for only 3GB VRAM. Small amount of storage to say it's gotta serve as a boot drive and storage for everything. That case looks like it'll make the components choke for air too.
https://linustechtips.com/topic/919704-pc-build-help/#findComment-11272507
Motherboard: Asus - PRIME X370-PRO ATX AM4 Motherboard  (£119.99 @ Aria PC)
Memory: *G.Skill - Trident Z 16GB (2 x 8GB) DDR4-3000 Memory  (£148.40 @ More Computers)
Storage: Crucial - MX500 250GB 2.5" Solid State Drive  (£62.20 @ Novatech)
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  (£46.95 @ Aria PC)
Video Card: *PNY - GeForce GTX 1060 6GB 6GB Video Card  (£238.46 @ Amazon UK)
Case: SHARKOON - TG5 ATX Mid Tower Case  (£64.99 @ Amazon UK)
Power Supply: be quiet! - Pure Power 10 CM 500W 80+ Silver Certified Semi-Modular ATX Power Supply  (£61.97 @ Amazon UK)
Wireless Network Adapter: Gigabyte - GC-WB867D-I PCI-Express x1 802.11a/b/g/n/ac Wi-Fi Adapter  (£24.46 @ Amazon UK)
Keyboard: G.Skill - Ripjaws KM570 RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Proteus Spectrum Wired Optical Mouse  (£59.99 @ Amazon UK)
Other: WIndow 10 (£28.00)
Total: £990.40
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/919704-pc-build-help/#findComment-11272514
Well there is nothing better and 3gb of Vram is plenty for 1080p gaming. Also IMO 500GB is fine, I use a 500GB each on both my desktop and laptop and not even used half
https://linustechtips.com/topic/919704-pc-build-help/#findComment-11272517
Total: £985.93
1. Why 2600X
2. mobo of unknown quality
3. no HDD??????
4. GPU is really bad value
5. Case has little airflow
6. RMx??? WHY?
7. No peripherals already 985 GBP
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/919704-pc-build-help/#findComment-11272521
One game can take up 20-30GB.
3GB VRAM struggles in many games already.
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/919704-pc-build-help/#findComment-11272524
I'd trade a 2600X for a last gen 1600 any day to get a better video card. (savings on both mobo and CPU). 1080p at £1000 is seriously underwhelming, I'd expect 4k at that sort of money. 500GB is tiny AF these days, hell in my main PC I have 4TB in total. RMx is stupid for what the OP needs, might as well go with the Bitfenix whisper that I recommended, system won't even draw close to the 450w of the whisper. HDD is recommended for LARGE capacity.
https://linustechtips.com/topic/919704-pc-build-help/#findComment-11272543
13 minutes ago, JDE said:
1. Why 2600X
3. no HDD??????
6. RMx??? WHY?
2
The 2600X boost higher so should be better in game, it comes with a better cooler vs the r5 2600.
The mobo is decent and supports newer feature such as boost 2.0, 2 m.2 slot which is not present on older board.
I personally don't use HDD because as I said I don't use that much space ( could be just me ).
True but it would go out of the budget otherwise
Well, the case offers great visual and build quality for a budget.
Cheapest gold power supply from brands I trust ( Corsair, Evga, Seasonic, Bequiet )
https://linustechtips.com/topic/919704-pc-build-help/#findComment-11272560
https://uk.pcpartpicker.com/list/92D4dX (im going to upgrade to 2x8gb of ram after its working and im also going to add a ssd)
intel core i5 8600k
coolermaster hyper 212 evo
asus prime b360 (im currently looking for a oc mobo for intel 1151 socket if you have any sugestions)
cooler master haf x
GET SOMETHING LIKE THIS...
CPU: Intel - Core i5-8600K 3.6GHz 6-Core Processor  (£191.99 @ Aria PC)
CPU Cooler: Corsair - H100i v2 70.7 CFM Liquid CPU Cooler  (£89.99 @ AWD-IT)
Motherboard: ASRock - Z370 Extreme4 ATX LGA1151 Motherboard  (£135.46 @ More Computers)
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-3200 Memory  (£173.67 @ Amazon UK)
Storage: SanDisk - SSD PLUS 240GB 2.5" Solid State Drive  (£54.98 @ Amazon UK)
Power Supply: SeaSonic - FOCUS Plus Gold 650W 80+ Gold Certified Fully-Modular ATX Power Supply  (£89.99 @ Amazon UK)
Total: £1078.55
Generated by PCPartPicker 2018-04-23 23:36 BST+0100
SSD TIER LIST
CPU - Ryzen 7 3700X
Mobo - ASRock X470 Taichi
Memory - G.Skill Trident Z RGB (8x2 3200MHz)
Storage - Sabrent Rocket 1TB - Seagate Barracuda 2TBWD Black 1TB
GPU - MSI GeForce GTX 980Ti LIGHTNING
CaseFractal Design Meshify C
PSUSuper Flower Leadex II Gold 650W
https://linustechtips.com/topic/919704-pc-build-help/#findComment-11273697
Total: £1078.55
thanks for the advice with the mobo and the gpu
https://linustechtips.com/topic/919704-pc-build-help/#findComment-11273760
That's alright mate??✌✌
Also don't get hyper 212 Evo fr that CPU...
Get that Corsair h100i that I HV mentioned above...
SSD TIER LIST
CPU - Ryzen 7 3700X
https://linustechtips.com/topic/919704-pc-build-help/#findComment-11273765
i have had a look and i dint realise it was a watercool aio i dont want to do water cooling yet in the future im going to try water cooling so ill keep this in mind
https://linustechtips.com/topic/919704-pc-build-help/#findComment-11273801
U won't be able to OC much using that hyper 212 Evo...
While.....using that h100i....u can OC it to about 5ghz
SSD TIER LIST
CPU - Ryzen 7 3700X
https://linustechtips.com/topic/919704-pc-build-help/#findComment-11273815
Just now, pipps17 said:
ok i didnt want to go into watercooling yet because isnt there maintenance involved and idk what im doin w it really
Having an aio is better than getting into water cooling...
My previous system was water cooled....ND the cooling fluid became so gross after 2-3 weeks..that it clogged the pipes....after that I quit water cooling...
Water cooling takes a lot of maintenance.....
SSD TIER LIST
CPU - Ryzen 7 3700X
https://linustechtips.com/topic/919704-pc-build-help/#findComment-11273829
isnt aio watercooling?
https://linustechtips.com/topic/919704-pc-build-help/#findComment-11273840
Kind of....
But there's no hassle in maintaining an aio..
It comes in as a single piece...
U don't need separate reservoirs,pumps,etc in aios.........
They are built-in in an aio...
SSD TIER LIST
CPU - Ryzen 7 3700X
https://linustechtips.com/topic/919704-pc-build-help/#findComment-11273845
