Dark Base Pro 900 Fan Controller Issue
Go to solution Solved by Morata,
9 hours ago, WoodenMarker said:
That indicates that the header you plugged the hub into is set to dc and not pwm.
I believe I have fixed it. I moved the fans to 2-4 so that the rpm reading is 0, and I changed the modes to PWM, along with using pump header 1 for the hub. Now, they are controlled and I have the minimum at 40% because under that seems to cause problems.
I’m having an issue with my Dark Base Pro 900’s Fan Controller.
The 3 included SW3 fans spin, but I can’t control them using my motherboard, desktop, or the included speed controller.
Any ideas?
Case: Dark Base Pro 900 (Black/Orange)
CPU: Ryzen 5900x
CPU Cooler: Noctua NH-D15 (LTT Special Edition)
Graphics Card: RTX 3090 Founders Edition
Motherboard: ASUS ROG Strix B550-F Gaming
RAM: Team T-Force Night Hawk RGB 32GB DDR4 3000 (2 x 16GB)
Storage (Boot): Samsung 990 PRO 2TB NVMe
Storage (Secondary): Samsung 980 PRO 2TB NVMe
Storage (Secondary): Samsung 850 EVO 1TB SATA III
Storage (Secondary): SanDisk Ultra II 960GB SATA III
Storage (Secondary): 2x Seagate 4TB SSHD (yes, really, solid-state hybrid drives in 2023)
PSU: Corsair RM1000x (80+ Gold)
OS: Windows 10 Home
Keyboard: Razer BlackWidow V3 Pro (with Razer Yellows)
Mouse: Razer Viper Ultimate Wireless
Mousemat: Razer Firefly Chroma Mousepad 2016
Headset: Logitech G533 Wireless Headset (still the best)
https://linustechtips.com/topic/919537-dark-base-pro-900-fan-controller-issue/
SW3 fans should be PWM capable to be controlled by your motherboard...
Community Standards
"Beast Mode"
Dedicated Streaming Rig
Yes, it is hooked into the motherboard but through the fan controller.
CPU: Ryzen 5900x
OS: Windows 10 Home
11 hours ago, Pangea2017 said:
Are you trying to run them at higher speeds? SW3 PWM are known for having a problem with these pwm settings. Adding a pull up can help.
I am not too sure what you mean by pull up?
CPU: Ryzen 5900x
OS: Windows 10 Home
14 minutes ago, Pangea2017 said:
At oc.net there was a post years ago with a explonation. You can also learn here more about it: http://thermalbench.com/2016/09/05/be-quiet-silent-wings-3-120-mm-fan/3/
I’m saying that mine aren’t changing speeds whatsoever from what I can tell, they seem to be running.
CPU: Ryzen 5900x
OS: Windows 10 Home
Is fan controller connected to mobo? Also, have you read manual on how controller works?
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
What motherboard do you have and which header is the fan hub plugged into? What fans settings have you tried?
Do you have 3pin or 4pin SW3's and which headers on the hub are the fans plugged into?
12 hours ago, Pangea2017 said:
What is your fan controller?
The included one with the be quiet dark base pro 900
CPU: Ryzen 5900x
OS: Windows 10 Home
Yes and be quiets manual is absolutely horrible.
CPU: Ryzen 5900x
OS: Windows 10 Home
I would suppose its a 4 pin, but it's been tried with 2 ports and I get no readings and the fans where pre-connected to the 4 pin headers.
CPU: Ryzen 5900x
OS: Windows 10 Home
Did you plug the fans into the 4pin headers on the hub? The rpm should only be read from the 1st header. If you haven't already, make sure the fan control switch behind the front door is switched to pwm mode as opposed to standard control.
It might be, but it still is quite clear on how to use hub. Set controller to 0 if you want to use motherboard. Which header on board you have tried? Manual says sys headers are DC by default so you need to switch them to PWM from BIOS.
They were already plugged in and I am not sure what you mean with the fan control switch, you mean the thing next to the LED switcher?
CPU: Ryzen 5900x
OS: Windows 10 Home
23 hours ago, Pangea2017 said:
Is your manuell controll set to 0 (the controll at the front of the case)?
Possibly, how can I tell?
CPU: Ryzen 5900x
OS: Windows 10 Home
Yes, I have tried that, I am on 2 right now, and I was on 3, still nothing, even in DC mode.
CPU: Ryzen 5900x
OS: Windows 10 Home
No matter which way I put the switch, it seems to do nothing.
CPU: Ryzen 5900x
OS: Windows 10 Home
Yes.
Just now, WoodenMarker said:
Yes.
It doesn't seem to do anything...
CPU: Ryzen 5900x
OS: Windows 10 Home
Which fan header on the motherboard is the hub plugged into and what motherboard fan settings are you using?
I have it on header 2 atm, and it doesn't matter what I use, nothing works. I tried manual 50, manual 100, and smart fan mode, nothing.
CPU: Ryzen 5900x
OS: Windows 10 Home
What motherboard do you have?
MSI Sli Plus z370
CPU: Ryzen 5900x
OS: Windows 10 Home
MSI Sli Plus z370
So the hub is plugged into sys_fan2? You should plug the hub into cpu_fan1 or pump_fan1 instead. Those two are pwm headers as opposed to the sys_fan headers which are dc.
Are they DC only? Are you sure?
CPU: Ryzen 5900x
OS: Windows 10 Home
It's in the motherboard manual.
