Dark Base Pro 900 Fan Controller Issue
Solved by Morata,
9 hours ago, WoodenMarker said:That indicates that the header you plugged the hub into is set to dc and not pwm.
I believe I have fixed it. I moved the fans to 2-4 so that the rpm reading is 0, and I changed the modes to PWM, along with using pump header 1 for the hub. Now, they are controlled and I have the minimum at 40% because under that seems to cause problems.
Featured Topics
Tamgam12 ·
Posted in New Builds and Planning5 -
remo233 ·
Posted in New Builds and Planning16 -
5
6
10
rickymohk ·
Posted in General Discussion3 -
Rbakker02 ·
Posted in General Discussion1 -
BaidDSB ·
Posted in General Discussion5
