Hi guys, I'm thinking of the buying the Coolermaster Masterbox lite 5 but i also saw the Sahara P35 Mid Tower Case, but i'm not sure which looks best and also i dont know which is better. Could you help me?
https://www.ebuyer.com/834538-sahara-p35-mid-tower-case-sha-p35w-f
https://www.ebuyer.com/789984-cooler-master-masterbox-lite-5-computer-case-at-ebuyer-com-mcw-l5s3-kann-01
https://linustechtips.com/topic/919339-what-case-should-i-use/
... HOW IS THE SAHARA P35 SO CHEAP?
I've never heard of them though it looks like it has better airflow.
Looks like you'll have to add your own fan btw
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/919339-what-case-should-i-use/#findComment-11268941
Just now, TH Gamer said:
This does not make sence at all
200mm fans, fans that can be put in 9
1 minute ago, TH Gamer said:
i know im going buy just blue fans (Game Max Mistral 32 x Blue LED 12cm Cooling Fan) all though is does support 9 fans, but  9 RGB fans from Corsair are really expensive
I'd rather get less RGB fans over more LED fans. LED fans generally are pretty terrible except maybe the Ringg
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/919339-what-case-should-i-use/#findComment-11268972
Either of those you posted will be fine.  The general in0-fashion these days is trending away from RGB front fans, so I'd go with the MasterBox Lite.  It does not come with any frontal intake fans though, so I'd order some.  However this is OK, as now you can get some top-notch fans to mount on the front.  The Fractal Design Venturi HF14s are amazing for airflow.
https://www.amazon.com/Fractal-Design-Venturi-HF-14-FD-FAN-VENT-HF14-BK/dp/B00VYEHUPE/ref=sr_1_1?ie=UTF8&qid=1524411148&sr=8-1&keywords=fractal+design+venturi+hf14
I edit the shit out of my posts.  Refresh before you respond.
https://linustechtips.com/topic/919339-what-case-should-i-use/#findComment-11269000
2 minutes ago, seon123 said:
2cm=20mm. That thing claims to be ~¾".
Was thinking dm :P
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/919339-what-case-should-i-use/#findComment-11269021
  • 2 months later...
The sahara's rrly gd! good material for the price. it beats anything in that price category. The cooler master masterbox is way to thermally restrictive which wil negatively impact performance
Main Rig
CPU: i5 8600k
Cooler: Deepcoo captain 240 ex white
Motherboard: Msi Z370 Pro Carbon
RAM: 16GB (2x8) Galax HOF DDR4 3600Mhz white
SSD: OCZ trion 200, adata sp900
Graphics Card: Galax GTX 1080ti HOF
Case: Nzxt S340 elite white
Power Supply: Gamemax RBG 1000w gold rated fully modular
https://linustechtips.com/topic/919339-what-case-should-i-use/#findComment-11558132
Necro lmao, this thread is 3 months old
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/919339-what-case-should-i-use/#findComment-11558522
