I'm planning to have only one ISP connection on my building and share it between the 6 apartments. This means needing to run Ethernet cables to all of them, creating some complications. My question: Is it possible to use the coax cables already present in order to simplify the job?
https://linustechtips.com/topic/919218-network-wiring-using-coax-cables/
Moca adapters are expensive. They max out at 400- 800 Mbps depending on what adapters you get. But yeah it can be done.
No experience with the adapters but here is what your looking for
