So I plan to Overclock my 1600 core by core, I cant find anything info on how to overclock per-core... and also with this cause any problems if different cores are different clock speeds.
I have a X370-F gaming Asus motherboard. I'm asking what voltages should I change for Ryzen overclocking, and what values should I use (Number values).
also the Asus bios had advanced settings like LLC and current values... don't know what they mean and how to use them, if you have tips here please share the knowledge.
https://linustechtips.com/topic/918442-per-core-overclocking-for-ryzen/
Most asus boards have a setting for the x-core ratio, where x spans from 1 to 6 (in your case). So if 1 core is in use, it'll be at that frequency. if 4 are, then the setting for 4, so on and so forth.
Haven't used an asus board on ryzen yet, or yours specifically for that matter, so I cannot promise that they implemented this for your board. But that's been a thing for a while now.
Main Rig: R9 5950X @ PBO, RTX 3090, 64 GB DDR4 3666, InWin 101, Full Hardline Watercooling
Server: R7 1700X @ 4.0 GHz, GTX 1080 Ti, 32GB DDR4 3000, Cooler Master NR200P, Full Soft Watercooling
LAN Rig: R5 3600X @ PBO, RTX 2070, 32 GB DDR4 3200, Dan Case A4-SFV V4, 120mm AIO for the CPU
HTPC: i7-7700K @ 4.6 GHz, GTX 1050 Ti, 16 GB DDR4 3200, AliExpress K39, IS-47K Cooler
Router: R3 2200G @ stock, 4GB DDR4 2400, what are cases, stock cooler
I don't have a problem...
